brake warning lamp test facility,
30 Oct 2011, 1:38pm
hi, ive fitted a handbrake warning lamp,abrake fluid level warning lamp,just read i need a test lamp facility for the low fluid level,is this correct,cheers
30 Oct 2011, 5:04pm
If you've used the same lamp for the handbrake and the fluid level, you can just use the handbrake lever for the test switch - if the light doesn't come on when the brake is on, the bulbs blown.
If you have separate lamps, you'll need a test switch for the brake fluid. A small momentary SPST switch hidden behind the dash should be ok for the IVA man.
