I haven't got that far yet.
But Im also interested in some pictures.
looking at my roll cage, the bar between the two roll cage uprights appears as if it needs to cut throught the fiberglass on the rear bulkhead.
It should be higher, my roll cage has already had to of been modified, due to manufacturing error, wondering if I have another manufacturing error here
It goes betweent the driver side roll bar and the passenger side roll bar.
You then loop the two top most harness straps around the bar, through holes in the seat back.
My concern is the holes for the bar in the roll cage appear to be too low to clear the rear fiber on the bulk head.
I think I will need to weld on a new plate, on the roll cage to increase the hole height and clear the fiber.
I guess you after some pictures of this set up?
Your right Steve. You won't be able to bolt through the seat belt mount hole straight into a tube. It hits the middle section.
I'll give it a go Sunday. But the idea I have at the minute, as a temp measure for the camera, is bolt tube to flate plate metal. Then bolt flat plate metal to seat belt mount.
Eventually getting correct strength tube and welding it.
My solution is to weld a plate on top of the bracket to "mirror" the bottom. if that makes sense.
Then use this plate with sutiable hole to mount the bar.
Can you not mount a camera using a roll cage mount hanging from the top?
Do you mean the seat belt bottom mount? On mine, the seat belt plate is at the top, not at the bottom if that makes sense.
Trouble is with mounting to the rollbar, is either the camera will be like one of those smart cars that fine you. With a lot of wind noise.
Or the camera will be mounted up side down as you can't rotate the camera 180 degrees.
Thanks John. Thats a great built in feature. Well thought out in every way. Everytime I read anything about the gopro, it just keeps getting better. Got fantastic reviews.
Hopefully know, after a bit of experimenting with positions, I'll get some decent videos in the Marlin. Also try it under water next month in Egypt.
