Hi all
I was using an original BMW steering wheel (air bag replaced with foam) with centre push for the horn, mainly because I couldn't fit the BMW slip ring to my nice Momo steering wheel.
I've decided to put the Momo steering wheel on, and use a spare push button space on the dash for the horn.
I've been using the Savage switches/buttons, which are wired as follows:
1. Power 12v positive
2. Source
3. Normally closed (not used)
A. LED (+) Power
B. LED (-) Ground
Then you put a link between pin 2 and pin A so the LED lights up when you switch it on.
Well because the horn switch is just connecting from the relay (ground output) to ground/chassis, I connected up pin 1 to the horn relay (was originally going to steering wheel) and connected pin 2 to earth, which works fine.
I originally tried pin 1 to the wire from the horn relay, linked pin 2 and pin A, and pin B to earth but the horn didn't work at all then.
So the led doesn't light up (I want the outer one to come on when the side lights come on, and the central one to come on when you press the horn). But I can't figure out how to do it...maybe I'm just being a bit dozy today!
Any ideas gratefully received!
Thanks
Tim
24 Oct 2009, 4:57pm
