Failed the re-test today, extremely frustrating. Only 2 points left on the list though:
1. Speedo. Having fitted an aftermarket device (reads the pulses off the bolts) to the rear O/S diff axle, the reading was too unstable to be read accurately. Initial solution will be to try a stronger bracket as I think the vibrations were affecting it.
2. Emissions. Last time they tested the right hand exhaust which failed. It passed this time! But then the guy (a different one to last time) had a look underneath and decided the left hand side exhaust should be tested as well as they have separate cats, and the left hand one failed. Grrrrr. New lambda sensor ???????
To be fair, the guy was very reasonable and friendly and I have no complaints.
One other point of interest: I had put in an E30 brake pressure regulator at the back as it had failed previously on the braking ratio between the 2 axles. Well this seems to have done the trick as it passed this this time.
Oh yeah one more thing, Jason, when you fill in your IVA form, I suggest you put down the axle weights as 500 and 600. I originally put down 500 and 550 as recommended by M..... but the back one came out on their test as 578 which of course was a fail point. It was no problem to redeclare the correct weight but ...
On the plus side, I drove it from Bath to Taunton and back with no problems (except I think the UJ on the front end of the prop shaft is knackered as there was a bit of vibration at high speed), great fun although it was flippin freezin! but God was the acceleration worth it
Tim
