check out the engine/clutch/trans package
10 Sep 2009, 6:45pm
Hey there everyone,
So I have a great deal on a complete engine / transaxle / adaptor / clutch package.
This is designed more for the track type build.
Here is what we have for you:
Engine is:
425HP Sealed LS1 Engine
(6800 Rev Limit, 400 Torque)
· Generation III Vortec Sealed Engine Assembly LS1
· PCM & Custom Wiring Harness
· Low Oil Pressure & Overheat Protection
· 525 Lift Hydraulic Roller Cam
· ATI Super Damper
· Water Pump (#16 Outlet)
· 100 Amp Alternator
· Steel Wet 8 Qt. Oil Pan
· Power Steering Pump
· Front Motor Mounts
· Electric Fuel Pump
· Inline Fuel Filter
· Serpentine Belt Drive
· Mass Air Flow Sensor
· Throttle Cable
· K & N Air Filter
· Installation Instructions
Engine does not have headers included, and does have about 100 laps on it, so is just getting broken in. This engine was built by Schwanke Engine, LLC. and retails for $8,800.00
Transaxle is Porsche 930 gearbox setup to run inverted. This is a very strong gearbox and will easily handle the HP and Torque of this engine.
A transaxle like this will normally retail in the neighborhood of $7500.00
The Clutch is a Kennedy Engineering Stage II clutch kit, and retails for $1500.00
The Adaptor kit is also made by Kennedy Engineering, and retails for approximately $550.00
Here is the best part everyone. I got a great deal on this and will happily pass the savings on to a lucky person. Price on the complete package....
$15,000.00 plus shipping. I truly doubt that I will have this for long so please get in touch with me right away if you want to pick this up.
Warmest Regards,
Erik Johnson
(303) 440-8899 work
(303) 895-4828 cell
