guidance needed please
13 Jul 2009, 1:38pm
ok,ive now decided to fit my rover 214i engine/box into my buggy,ive got the complete lot mounted in the rear of her,so now i have the front brakes(discs) on the rear,what would be the best solution in the way of front brakes for her,bearing in mind i need a handbrake which i thought could be off a vw rear caliper mounted to vw discs?? yes i understand i will need to fit a brake force distributer of some sort because it will be seriously over braked on the rear,would vw golf rear system be enough? the buggy weight will be circa 450kg.your brainstorming will be greatly appreciated.
thanks in advance,andy
13 Jul 2009, 2:05pm
Use the same setup at the front as you have on the rear, use the standard hubs and get a set of driveshafts from the breakers, remove the shaft so you are left with just the hub end section and get it machined down so when it is fitted through the hub the rear face is flush. On the rear, fit a pair of handbraked rear calipers solely for the hand brake.
you will be suprised how good the distribution will be when using the same calipers all round without a proportioning valve. As long as the front brakes lock first then it will be fine - otherwise you need to fit a proportioning valve which cannot be operated/adjusted by the driver when seated as they test from one extreeme to the other.
13 Jul 2009, 5:35pm
great help thankyou,do u know what rear handbraked caliper will fit my rover front discs/hubs? thanks again:wave:
14 Jul 2009, 7:29am
I'm afraid thats a trip to the breakers with a veriner caliper / tape measure to check rear disc widths vs caliper. MG did a rear vented ZR so that would be wider. Other than that there is a specific handbrake caliper available from Hi-Spec brakes which is not too bad value.
14 Jul 2009, 5:42pm
great link that thanks,
and now for my next trick question.....................
now that i have a front wheel drive engine in the back of my buggy,what the hell am i going to do with the gear change system,unfortunatly its got steel rods and not cables!!!!
15 Jul 2009, 8:35am
Simples, turn the rod round and add a bit or convert to cable.
15 Jul 2009, 9:46am
Just a suggestion but Citroen BX handbrake is via the front calipers and would be a solution.
An adjustable bias valve (about 40 quid) for the brakes could be set and then rendered tamper proof for the test, very handy afterwards for altering bias for different road conditions with a lightweight car. :eusa_angel:
16 Jul 2009, 2:50pm
Forgot about the citroen BX handbrake, that would solve quite a few problems and probably cost less than getting a seperate handbrake caliper on the rear
16 Jul 2009, 6:14pm
yes,im gonna trawl the scrappers on saturday,thanks.
with the engine sat in place theres not much room to fit a decent set of double a arms on the right side of car because of the engine being "to the right",theres quite a lot on the gearbox side though. the only way i can see is to get some longer driveshafts?chris do you know what will do/fit? i dont want only 6" long a arms like them bruddy ugly quadzilla or pgo buggy things.i like very wide arms!
17 Jul 2009, 7:32am
the local parts shop (the smaller one man band jobbies) should have a driveshafts catalogue to trawl through to make sure you get the right ends. It would probably be best to try and get hold of a suspension book to read through, otherwise you will probably end up with buggy that handles like a deathtrap
17 Jul 2009, 12:11pm
It's a pitty it was not the Rover PG1 box (On 218's). They have different length driveshafts for there other cars (200,400, 600 & 800).
17 Jul 2009, 1:22pm
yes,suspension is an art but something i can manage as i make custom quad+atv a arms myself. i have a street legal yamaha banshee 370,you should see how wide she is! ill try post a link now.......
im currently converting her to reverse cylinder yam power valve system with zeeltronic programable ign and self made(designed by computer software) gp reverse cyl pipes,should be in the region of 80hp,(now shes circa 65hp,standard is 46hp)if anyones interested i can post link to my album.
regards andy.
17 Jul 2009, 1:46pm
Some pictures of your build would be good to see.
limpabit used a linking driveshaft on his audi conversion to get equal length driveshafts.
you might think about getting a PG1 k-series box as it is stronger than the R65 and you can get LSD's for them easily
17 Jul 2009, 2:21pm
Just standard mg v6 driveshafts. That's how they come. By chance, the V6 uses a pg1 as well.
17 Jul 2009, 6:13pm
my disc drive on my laptop is broke and i cant download the software for my new phone,if i picture textd someone by mobile could they be so nice as to post em for me plz??
17 Jul 2009, 10:22pm
If you converted to PG1 box you could then use the cable shift from MGF - MGTF - Lotus Elise
