EDIT - Title should be SVA Dashboard edge trim - but it seems that you can't edit the title...
What did you guys use for the dashboard lower edge? The SVA manual states a radius of 5mm if using a deformable material - else 19mm. I don't think that the standard "titanfast" edge trim will provide this.
PS - sent of my SVA application yesterday so it's all hands to the pumps now....
You have to glue it on.
Your right in thinking the titanfast is too hard.
I also had some pipe insulation covered in black vinyl which was slotted and could be clipped over this stuff as a back up if required but the above was checked and not questioned.
