Date for last SVA test
30 Jan 2009, 1:34pm
I think most of us are aware that the last SVA test will take place at the end of April but does anyone know the cutoff date for applying?
I was going to wait for the new IVA but it seems it will be much more expensive (£500+ arghhh) so I might see if I can finish my build in time for the SVA.
30 Jan 2009, 1:56pm
It's either very soon or just gone. Got an icling it was either end Jan or end Feb. You could try ringing the DVLA to confirm, they were quite helpfull when i spoke to them - you do have to ask for the "SVA Testing And Support Services" tem when you get through to an operator
30 Jan 2009, 4:51pm
Bother (or words to that effect). I contacted Vosa today and they confirmed that they haven't published a price for the new test yet so I don't know where the £500+ figure I saw in the Kit Car mag came from. Perhaps they have inside information....
30 Jan 2009, 5:04pm
Thing is they were being buggers back in September when I put my application trying to delay my application until it was too late, suggesting it would be near impossible to get an application and test done within the time limit.
Although the actual cost is not known yet, the tester I had suggested that it was generally acknowledged within VOSA that it would be considerably more expensive and definately "no easier" to pass
30 Jan 2009, 8:49pm
When I booked mine there was a long waiting list. I paid extra to have an 'out of hours' test which then got me a more reasonable date. (mine started at 7am which was classed as 'out of hours'). I can't rember the extra fee but it is on the SVA application form in the price section. Also, it appeared that some test stations had much longer waiting lists than others, so you have to ring around.
It might be worth getting an SVA test booked, as even if you pay extra it will be cheaper than the IVA. If it fails I assume you'd pay the SVA re-test fee?
Another point is that you put your application in and then a few weeks later they write to you asking for evidence that you built it. You then send them a load of photos in the post and then you you wait another couple of weeks while you wait for yours to get to the top of the pile!! The morale is, don't leave it too long!
I'd get an SVA test booked as close as possible to the last available date and go for it!
3 Feb 2009, 5:07pm
Thanks Timbo
So the last date to apply for a test is the end of this month (February) and the last actual test is the 28th of April. But.....
You can have a retest up to 6 months after so best to get the car tested now and, even if you fail, you then don't have to do the IVA (and pay whatever the new fee is) as long as you fix the problems within 6 months.
Think I will go for it as well....
11 Mar 2009, 1:33pm
Dont know if you have applied yet bvut the cut off for applications has been extended until 20th march
11 Mar 2009, 1:40pm
Thanks - yes I have applied. My test is on the 21st of April. If they have changed the last date you can apply I wonder if the last date that you can have a test has also changed?
