Forum Home
Mad Build Area
Marlin 5exi builds
Turning circle?
Turning circle?
I know this has been discussed before but I have spent half an hour and can't find anything!
Can someone please tell me what I need to take off/do to improve the turning circle?
Is it under the rack boots?
Craig
Unclip the rack boots. You will then see white plastic rings around the rack - they are about 20mm thick (as measured along the rack).
I found the easiest way to remove them, was to split them with a wood chissel.
You'll breath a sigh of relief when you take the limiters off - you'll no longer look totally incompetent when trying to park.
Cheers John, it's done
Craig
