Injection issue
9 May 2008, 3:20pm
I have had a cold start problem with my car ever since I built it, over time I have replaced all the necessary sensors, and some probaly not so. I have replaced the distributer cap rotar arm plugs and leads, and now after all that I now have injector issues.
Number 1 and 4 are not clicking / firing so I am running on 2 and 3, so not very good, all thought gratefully accepted.
The engine is a 96 1.6 k series.
Steve
9 May 2008, 4:28pm
Have you checked for a signal at the injectors? Not easy with a 'scope I would imagine. Does the Rover ECU pair injectors to a driver?
9 May 2008, 5:34pm
I have only checked for power with amulti meter, and yes they are paired. When you pull off the plug lead there is no change. I am thinling myself about the ecu driver.
9 May 2008, 6:22pm
Hi steve I'm no good with stuff like this but have you tried seloc? same engine and loads of knowledge on there!
Craig
9 May 2008, 6:28pm
I presume like most ecus, the ecu switches to earth to fire the injector. Is there 12v on one side of the injector plug with the ignition on?
Sounds to me like the easiest solution is to try another ecu. I guess ecus are 10 a penny, but a matching ecu and transponder is a bit harder to acquire.
10 May 2008, 6:10am
Hi Steve.
Yep there grouped in pairs. 1&4 and 2&3. they all have a common +ve. Brown/pink wire. Should be getting 12V on all these with a good earth point.
Is the car driveable? Could have plugged in the diags to see if anything shows up. If I get mine on the road today, will make a little trip down. Depending on weather.
Scratches head trying to think of another 1.6 ECU that is about to borrow. Closest to me is DavidH I can think of. Still a couple of hours drive away though.
