I have been fitting the boot floor today and it's pretty obvious that the inertia reel seatbelts that I bought are not going to fit - at least without some major surgery...
So I am going to buy some static belts. Which ones have you guys used and do you have any advice on what to do and not to do?
Part No: SPC04608BVSGR Status: Special Order Only.
Item Price: £45.53 Surcharge: £0.00 Price: £45.53
£53.50 (exc.Vat)
(inc.Vat)
Description: SPARCO 3 POINT ROAD HARNESS, SILVER: PUSH BUTTON BUCKLE, FIXED POINT TYPE
Other Info: EEC HOMOLOGATED, NOT FIA APPROVED
Well that's a shame, the inertia's sound like a good idea.
I got mine direct from Marlin. They are TRS Motorsport. The box says "Clubman 3 point MH330-1003" and they are black. I have not "test driven" them yet, but they seem nice quality. http://www.totalrestraint.com/harness/
cheers
Thanks Peter
They seem to be good. Patrick's Sparco alternative are a bit pricey...
The MH330 seems to be available in black, red, green, blue, violet, yellow and pink!
Hmmm - decisions, decisions....
So - Am I correct in thinking that this harness mounts with eybolts?
Don't forget you need a seatbelt bar that fits between the suspension turrets.
The belts go above the bar and holds the belts up at shoulder height to meet the SVA requirement.
If you buy the seatbelts direct from Marlin you get the bar included.
cheers
Peter - do your seatbelts do a two into one at the back - with a single strap then down to the mounting point? I bought some direct from a TRS supplier and
A. They are too short
B. They have two straps all the way back to the single rear mount.
