Hi, I have wired my indicators tonight and although they work they flash quick! Like when you have a bulb out??
Not sure why yet but was wondering where the feed for the side repeaters comes from as I have taken mine from the front of the respective sides and maybe this is wrong??
If your using the Marlin loom, there should be side repeater wires already there. If not it should be just a matter of connecting to the respective side indictor feeds.
Have you got all the bulbs in left/right front/back?
On a positive note though I (think) I only really have left wiring wise!
hazards switch
fog light and switch
reverse wired up but not tested yet
and speedo but judging by all my other smiths gauges it should be simple as they only took about 10mins each
Must admit I will be happy when the wiring is finished!!
Hi,
I used a savage switch. My diagram was like so:
F15 is switched +ve, F14 is perm.
The two lines out bottom left are the feeds to the lamps (and dash warning lights). I didn't bother to show the illumination for the switch.
Richard
