Hi guys,
The top of tranmission tunnel on the chassis is only stitch welded to the sides (no continuous bead of weld), so I guess I need to seal the seam between the three pieces of sheet metal.
Looking through the Frosts catalogue, I come across this stuff:
http://www.frost.co.uk/item_Detail.asp?productID=8320&frostProductName=Joint%20Sealer%20-%20Black%20(310ml)&frostCat=Fillers&frostSubCat=&frostubCatID=
Is this the right sort of stuff to use? I was going to run a bead of filler along the underside of the seam, let it go off and then over paint with some POR15.
Ta,
Jason
1 Mar 2007, 3:32pm
