Sunday
Paul, thanks for the diagrams, they did help, and you are right about the Spitfire 1500, and so is 8 valve Ed.
However.............. Although my donar Spit came with a 1500 engine, that engine was retro-fitted by the last owner, and my Spitfire is actually a Mark 1V.
Just for interest, the car would have been fitted with a 1300 engine originally,
which is a better unit than the 1500, but there we go.....
Being a Mk 1V, some of the wiring is different to that on a true 1500.
The car I have does not have a hazard flasher unit fitted, and it is not present in the wiring diagram either.
Having said all that, I have found my car's indicator flasher unit, and it does work when given a live feed. I jury rigged it and got the flashers all going, so I will fit a double pole switch, and get it to hazard flash, ex-ignition circuit like Ed suggested.
Ed, glad to hear you have sorted your flashers out!
You will have read the above bit to Paul, which will explain where I am at now.
What a palaver, but slowly it is coming together.
Today I got the fuel gauge and water gauge working, and decided to change both (Spitfire) of them in my new dash for proper Jaguar ones.
The jag ones were rusty and mucky, so I gave them a brush up, and fitted them in my dash, and they are an improvement on the Spitfire ones.
I also tried to fit the chrome headlight rings that I had bought at Stoneleigh,
only to find that they would not fit behind the headlights, as there was just not enough room. The cowl-space was too narrow to allow the rings in at the back.
Not to be outdone, and determined to fit them, I chopped them down a bit thinner by slicing them almost in half, and that did the trick and now they fit a treat, and the butchery cannot be seen behind the scenes!
I also painted them to stop the rust.
All in all a good productive day.
[IMG]
[/IMG]
[IMG]
[/IMG]
[IMG]
[/IMG]
[IMG]
[/IMG]
[IMG]
[/IMG]
[IMG]
[/IMG]
