DaveP - Cheers.
The scary thing about the Tribute "sticky", is the sheer number of new models that have already been finished.
( As the A352, Z300, Kobra & 250 SWB models were all introduced
after I started this build.
Next week marks 4 years since I bought my donor car and I still don't know when I will finally be on the road.
Hopefully, the "all new Sammio Spyder" will bring these much shorter Tribute build times to the world of Sammio.
Talking of build times, the fact
Swifty built his Navigator in 2 years, with so many bespoke parts is amazing.
RedRatBike: - Oi cheeky!
Thankfully there always seems to be building work going on in our street, so I'm not the only one making noise.
But I have cleaned up my dusty mess from my neighbours' front gardens on both sides more than once.
Hands on Fire:
Woke up at Silly O'Clock this morning due to the fibreglass itching in my hands.
The space around the arch panels is so tight I've not been able to wear gloves for a lot of the sanding work.
Which has lead to my hands getting scraped a lot, in addition to picking up the usual fibreglass splinters.
It took a while before some hand cream calmed them down enough for me to go back to bed.
Monday Morning:
Despite the bad night's sleep & my wife
volunteering me to drive my daughters to school this morning, at least it was dry outside.
Started by removing the wheels (again) and leaving them in their temporary home in the porch.
Spent a while grinding/sanding down any stray bits of fibreglass matting / bonding paste from the other day.
I also hoovered the inside of the cockpit as there is dust everywhere and cleaned up the areas I wanted to work on.
I did two rounds of bonding paste to cover a number of areas:
Finished sealing the gap between the framework and the body shell on the driver's side.
You can also see that the bottom fibreglass panel I fitted has been entombed in bonding paste.
I adopted the same approach on the passenger side.
Just to put this photo in context, it is at the bottom of the panel work joining the leading edge of the rear wheel arch.
Finally, more bonding paste was added to the
inside edges of the leading edge arch panelling work (via the cockpit).
Passenger Side:
Driver's Side:
Thankfully, all of this mess will be out of view behind the internal cockpit panels.
Although I will not start fitting those panels until I have added the final inner wheel aluminium panels.
Whilst the panels joining the
Moon Rover to the body shell resemble a patch work quilt, they have a real strength now.
I am sure there are easier/quicker ways of doing this, but I am just pleased that it actually seems to work. <
Touch Wood >
With a bit of luck I will get a chance to play with the tail pipe brackets this afternoon.
Until then, take care, Paul.
