The nice man delivered this spiffing Ebay item the other day. The hydraulic seals have been renewed and it was mine for only £75 including carriage. Result! They're Spitfire, for those of you unfamiliar.
I now have everything I need for final assembly, apart from whatever will need doing to the as yet uninvestigated front brakes.
Can't think where else to put this. It was my original kit car inspiration. I sold my Lotus VI to a school friend in '71 for £100. He's shunted it from one garage to another for nigh on 50 years without putting it back on the road.
I think most of us 'mature' people have similar stories. Mine are a '32 MG PA sold for £75 which was a profit of £50! An AH3000 MK1 Bought for £200 and sold for £50, well on the way to a heap of rust. A mate of mine bought a Singer sports car in the 60's for £60, sold it a couple of years later for £60 and saw in auctioned for £60K!
Why would it not be possible to get this through IVA? Is there something fundamental about its design that would cause a problem? Or is it the effort required in getting all the details right?
I'm just curious. I built my kit car in the days before SVA / IVA.
Why would it not be possible to get this through IVA? Is there something fundamental about its design that would cause a problem? Or is it the effort required in getting all the details right? I'm just curious. I built my kit car in the days before SVA / IVA.
It's possible to get almost anything through IVA if sufficient effort is applied. At present all the modifications required can be reversed once approval is granted, making rather a mockery of the process. I understand that the Westfield Owners' Club has a kit of the necessary parts for hire to get the Lotus XI evocation through.
That yellow Monaco would need some serious work to meet all the requirements, whereas mine is simply a re-body, or 'Radically Altered Vehicle' as DVLA style it. Its unmodified Spitfire underpinnings constitute its identity, irrespective of whatever bodywork is fitted. Witness my A352 which is styled on its post-V627 process V5: Make: Triumph; Model: Spitfire; Body: Sports.
I imagine that my Monaco will be similarly described.
Thanks for the helpful reply.
I get the difference between a ‘rebody’ and an ‘IVA’ car, and I understand that things sometimes ‘fall off’ after IVA.
I was just wondering if there was anything specific about this car that would be a problem for IVA. I suspected it is a case that almost anything can be made to pass, it’s just a question of will and effort.
Saw a D type in the same colour and white flash on the front on the A30 near Sunningdale. Looked and sounded great, was it you?
Afraid not. Perhaps it was this one, with the new owner popping over to Blighty to show off his (her?) multi million £ new toy?
Seriously though, it's possible that it's the one mentioned at the end of this post? There are probably a few similar scattered around the country but the likelihood of their being used for trips to Asda, like mine, is remote!
The one I saw didn't have a roundal on the bonnet. It did sound like a Jag. Looked bigger than the car I saw at Tribute but it went past in a flash.
Spoilt for car spotting around here, I have Marenello's at the bottom of the hill, new Mclaren garage in Ascot (factory is only a few miles away) and Duncan Hamilton over Bagshot way. Plus a Tacky Rolls Royce dealership in Sunningdale, how can you have that much money and so little taste?
Yesterday, for the first time in earnest since June 3rd, I ventured down to the deliciously cool man cave to play with the Monaco. After a bit of a tidy up of some boxes of my children's stuff stored there, and a once over with the yard brush, I had to decide on something simple to ease myself back into the build.
I've never really been happy with my upper seat belt eye bolts, positioned as they are to crack the odd vertebra or two in the event of being hit from the rear, so I decided to reverse them, which will allow the mounting plates with their captive nuts to be recessed into the plywood seat back. The belts themselves would have to emerge through the rear deck with this arrangement so I set to measuring and marking where the holes would have to be cut. To make this arrangement tidy, and please the MOT inspector, I decided that ally escutcheons were needed.
I made a card template, transferred the outline to ally sheet, and tin-snipped out the blanks. I cut the central slots with wood chisels and bent the flaps in the vice by tapping a piece of thick steel through, before drilling the rivet holes.. A trial fit of the belt end plates verified that my measurements were correct. The slightly ragged ends of the slots will have to be dressed in situ.
By this time the early afternoon sun was streaming into the cave and the thought of getting into the hooded paper suit to cut the slots in the body decided me to leave that for another day.
I'd long ago realised that, whichever pedal box I used, an access panel would be needed for the master cylinders. After some more careful measuring of the position of the footwell bulkhead and the pedal box, I marked the body ready for cutting which, again, will have to wait for a cooler day.
I wandered down to the man cave mid morning yesterday and decided to make a little more progress. Out came the drill and the jigsaw and I attacked the access panel outline, hoping that my measurements were correct. After vacuuming the doom dust, as I call it, and removing the protective gear it was time to offer up the pedal box.
I tried balancing it on bits of wood but it didn't want to play so I strung it up Heath Robinson style. The oversized reservoir on the brake master cylinder made optimal positioning impossible so I removed it, I'll have to substitute a regular sized one. I also disced off the top right hand corner of the mounting plate to make it fit up against the footwell more snugly.
Now happy with the way it sat I put it back on the bench to ponder how I would attach it. The front facing bolts can easily be substituted with appropriately longer ones to pass through the bulkhead with a reinforcing plate on the engine bay side. The vertical facing ones will need a transverse bar attached to the body sides to locate them. This will need to be angle.
By now, the noonday sun was turning the cave into an oven, so I packed up.
Hi Mick,
With the seatbelt eyes/mounts is there a frame behind the fibreglass shell, that they mount to/through?
Could you post a picture, as I'm about to install mine.
I wandered down to the cave yesterday and measured the body width and pedal box mounting area. Logging on to Ebay I bought the necessary 3mm steel plate and 20x20x3mm steel angle. A trip to my local fixings factor, Allcap, and I bought the ten 2" long 1/2" UNF screws c/w penny and split washers I needed. This emporium has never let me down, no matter how obscure the specimen fixing I've presented for duplication, and it's maintained its £4.00 + VAT minimum charge, and all practically on my doorstep. Excellent!
My 3mm steel plate having been left on my doorstep whilst I was out , I was able to crack on yesterday. Before cutting any metal, I made a template of the curvature of the body to ensure a snug fit of the mounting. I used cardboard on the outside and transferred the profile to another piece of pizza carton which, when offered up in the footwell, was acceptable.
Examining the ally mounting plate revealed that it would be severely weakened once the vertical element (which I'm replacing with the steel) was removed. I cut off a strip, bent it into an angle, rivetted it on, and disced off the redundant section.
Using the template and the above section I marked, jigsawed and drilled the new plate with the mounting holes centralised.
A little dressing with the rat tailed file and the footwell side of the steel sandwich mounting was temporarily bolted to the pedals.
My fillings having nearly been shaken out whilst using the jigsaw, I decided to quit while I was ahead and leave the second plate for another day.
I find a 1mm thick cutting disc in an angle grinder is the quickest and easiest way of cutting thicker steel. The 1mm discs cut very quickly but also wear out very quickly so buy in bulk and invest in a quick change angle grinder nut.
I generally use mine for straight cuts, but find the jigsaw's easier for curves.
Yesterday I marked out and cut the second mounting plate which will be on the engine bay side of the bulkhead, creating a metal sandwich.
I then cut the necessary slots in the rear deck and rivetted the two escutcheons in place. The edges of both the slot and the flange needed a little dressing, which I did after taking this.
No. 2 son works on Tuesdays, so I couldn't press on with the pedal box mounting as this will have to be done with the body off. Maybe today?
Yesterday's task was to mark the locations of the forward radius arm mountings on the underside of the body. Like the pedal box, they will have substantial 3mm steel sandwich plates to ensure a sturdy mounting. Ever cautious, I decided to check the wheelbase dimension as I've noticed, when pushing the beast in and out of the cave, that the back wheels move a little fore and aft. The book of words gave the dimension as 83" so I fabricated a demon measuring stick with 1¾" wire ovals protruding at the required spacing. The gap was approximately ¼" too great so I used a ratchet strap to pull things into line. I could then support the mounting plate and attached radius arm gently against the underside with the scissor jack and mark its outline. Repeat for other side.
My son wandered down the garden at this stage to ask if I wanted to take the body off but, once again, it was simply too hot to continue so I packed up.
Tuesday and yesterday I applied myself to fitting the beefier M10 Range Rover wheel studs to the front hubs. I'd fitted the more straightforward rear ones some time ago and had been feebly putting off this task.
Starting with the offside one (nearer to the workbench), I clamped the disc in the vice and tried to get a socket over the head of the first of the four bolts securing it to the hub. The shape of the casting prevented a very secure location so I substituted a ring spanner tapped on with a hammer and bashed its end to start things off. After a few goes it was proud enough to get the socket on and gently undo it. This worked fine for another two of the bolts but the fourth stubbornly resisted, even after lots of dismantling fluid and heat. I decided to leave it in soak overnight and try again mañana.
Yesterday morning, no change, even after lots of heat. I bit the bullet and used a 4mm HSS bit and my smallest cold chisel to relieve the offending part of the casting. The last bolt then came away easily. Tapping the hub from the disc and drawing the new studs through their holes with a wheel over it, using the new nuts, was simple, as was re-assembly. The near side hub, although identical as far as I could see, proved simplicity itself, the socket being fine on all four bolts. Weird.
Next job was to run my MGF wheels down to the tyre place, agree on 175 65 15s and leave them there for collection today.
Body removal assistance was was once again unavailable so I decided to paint my pedal box sandwich plates. My new litre of acetone had arrived earlier so a quick degrease and a few passes with a rattle can had this done.. The paint is matt black but the photo' has lied, showing it as grey. More weirdness.
and bought five new tyres for a project . The anticipated 'phone call came late morning and I whizzed down to the tyre place in the Micra, armed with a picture of a Monaco. The guy on the desk had asked me what car my tyres were for, and I'd replied that he wouldn't know if I told him. Anyway, both he and his boss (top bloke, he'd left ProTyre to set up on his own, taking most of their staff with him) asked me to bring it along when it's done.
On return, as help was available, I pressed on with the pedal box after plonking the body on the grass. I'd made a cardboard template of the mounting plate showing where the pedals hung and offered it up in the engine bay to mark the first of the mounting holes, making sure that the steering column hole was between the pedal positions. Once the first hole was drilled, it was a simple matter to bolt the plate into position and drill though it for the other five. The two large holes were already cut when I got the project, as was the steering column one, which luckily turned out to be spot on. I'll fill the biggies before final assembly.
The day was marching on by now, and my son was going to work, so I enlisted his aid and replaced the body. All that was left was to fit my MGF wheels .
The back ones may need slim spacers, time will tell, and the fronts may necessitate limiting the lock with hose clips. Again, the proof of the pudding....
I have to say that I'm thrilled with the way she looks with her new boots, much more in keeping with the overall look than the 13" ones!
