IanA's Z300S Barchetta Build
8 Nov 2017, 5:39pm
Great find, just bookmarked the 2001 for myself.
4 Apr 2018, 4:04pm
Now MOTed for another year and still saving up to get it painted.
Slight increase up to 1745 miles in the last 12 months.
Had to replace the driver's seat fuse to make it adjustable again for the test. Apparently there is a draft MOT "additions" document around showing that from May the test could include brake fluid appearance and reversing light checks.
Found the document here
10 Apr 2018, 1:42pm
1330 Kg
Just been out for a spin down to a local weighbridge and the Z300S with a quarter tank of fuel weighs 1330 Kg.
It still has the front & rear alloy "bumpers" under the bodywork and carries a space-save spare wheel.
10 Apr 2018, 3:57pm
BMW claimed 1387KG for the 2.8 but I guess that was dry weight
10 Apr 2018, 6:53pm
Fairly certain that is is dry weight too.
4 May 2018, 12:09pm
Out for a spin in the Z300S earlier this week and upon checking (as you do) found that the brake lights weren't working.
Wiring connections in the well of darkness (the boot) looked OK and the fuse wasn't blown.
Having the engine running and idly pumping the brake pedal listening for the switch to click- they started working again.
The switch was just tired I guess...
If only all gremlins would dissipate as easily.
4 May 2018, 12:57pm
I have an intermittent short between the brake lights and the rear indicator on the passenger side. Most of the time it is fine and then when braking and turning left the indicator suddenly starts flashing at double speed. I have been trying to track it down for 18 months on and off
4 May 2018, 1:05pm
Easy fix, you're driving a BMW, you don't need to use indicators.
4 May 2018, 1:24pm
Like the Mrs, just wants to let you know you cannot take it for granted.
20 Jun 2018, 8:36pm
Getting close to paint time
Getting close to paint time as I've found someone fairly local who will do a standard paint only job (no lacquer) with a pro-finish vinyl striping overlay.
A few more consultations needed but he's recommended Indasa Autofill for any filling, pre-primer that it may need. Anyone else used this stuff?
Sounds like an easy-sand paste with glass and kevlar reinforcement. I have to say that the Isopon P40 with glass strands is not the easiest to sand.
21 Jun 2018, 8:31pm
Ian - Remind me, what colour are you going for?
21 Jun 2018, 9:13pm
Thanks- this is the car's 4th summer in gel coat.
Same as ever- white- probably Ford Polar or Arctic or whatever they call it this year with 2 stripes in red - probably good old Standard Triumph Signal Red vinyl.
25 Jul 2018, 3:04pm
Here's a (seemingly) odd question......... Does the Barchetta body kit come with the headlight holes already cut out, or just marked? No prizes (but maybe some kudos?) to anyone who can guess what I'm thinking (clue - not a track car without lights)
25 Jul 2018, 6:51pm
Mitchelkitman wrote:
... guess what I'm thinking...
Chris installed the headlights in mine so I can't say. There was a pic on here a little while ago of Z300S kit #7 being shipped. You may be able to see on that.
Are you going to:
A. Install a cluster of white LED lights for the front?
or
B. Install a cluster of red/amber LED lights and mount it on the back a la Boxster, Nikri and other pushme-pullyou designs?
25 Jul 2018, 8:18pm
Another clue - using traditional headlights :wacko:
26 Jul 2018, 4:28pm
You got it! My thought is that it would be a fun feature to have rotating headlights ALA Panther Solo. If the part cut out is available (or marked so it can be carefully cut out) it will be used as the 'blanking piece' when the light isn't in use.
26 Jul 2018, 8:25pm
I went for 'Frenched in' rear lights but have always love novel pop up style lights.
Rotating lights, ones where the bonnet lowers, simple pop ups like on my TVR Wedge.
I think the only ones I didn't like were the 'lazy eye' ones on the Z280 where the lower half was left uncovered .
26 Jul 2018, 9:16pm
They are IMHO an interesting feature. I changed my Quantum ones from pop-down flaps to pop-up headlights - main reason was that the original set up gave very poor night vision (beams shielded by bodywork) and MOT query due to light shining off flap.
5 Aug 2018, 10:01am
A-Plan insurance
Originally Posted by ned
try 01635 874646 and ask for kit car dept Henry
good luck
IanA wrote:
That would be their Thatcham branch that I normally deal with anyway.
My renewal came through at £280.
So I called them today and and they quoted £148 (includes business use) and then knocked off another £20 when I let them quote for my house insurance- result!!!
Thanks for the info- a beer is waiting.
Just wanted to get this info on my thread.
5 Aug 2018, 6:54pm
OBDII Bluetooth Scanner
I've just picked up one of these for £4.30 and downloaded the OBD Car Doctor app from elm327.com onto my Android phone.
The free app is fairly basic- rpm, coolant temperature and not much more. The full functions only become available when paying for the Pro version. (~£14)
Not sure how much info is available on the Z3 as its OBD is not fully compliant but I would expect to see trouble and servicing codes and be able to switch them off. There is also a data logger function.
6 Aug 2018, 8:03pm
IanA wrote:
I've just picked up one of these for £3.79 and downloaded the OBD Car Doctor app from elm327.com onto my Android phone.
And now I've upgraded to the Pro version. (£13.49)
Interesting range of functions:
Road speed
RPM
Intake Air Temperature
Engine Coolant Temperature
Fuel consumption
Diagnostic Codes (library of 18193) (reset them with ignition on and engine off)
% Engine Load
Short Term Fuel Trim Banks 1 & 2
Long Term Fuel Trim Banks 1 & 2
Ignition Timing on #1 cylinder
Airflow Rate through MAF in g/second
Oxygen Sensor voltage and % Banks 1 & 2
Battery Voltage
but no ECU info (probably the Z3 non-compliant bit).
So basically- a whole load more things to worry about !!!
18 Aug 2018, 7:16pm
More pre-paint help please
More pre-paint help please:
1. How to remove Z3 door handles? I've got the clips off of the front pins but how to access the rear fastening?
2. How to remove the outer door top rubber trim? I'm guessing that loosening/removing the front window runner and quarterlight should provide access. I've found 2 bolts holding those.
