1iTim's triumph miglia special
25 May 2015, 5:39pm
Tim, I cut them with an angle grinder. I just got some steel and clamped it underneath so I could draw inside of chassis rail and outriggers etc...
Then drew a line approx 15mm from each edge, which gave me the floor area. The decided that the drop was 75mm, reducing to 25mm at the rear
25 May 2015, 8:42pm
Thanks Gary. And th cool swage wheelIe thing? What's that called? Might have to get myself one of those too.
(The box of goodies is about half way through the Suez Canal now)
Tim
25 May 2015, 11:09pm
It will have covered some miles before it even gets on the road! :eusa_angel:
25 May 2015, 11:24pm
It's certainly better travelled than I am!
26 May 2015, 7:45am
Tim, it's a beading tool. Just don't make the panels to big to handle...
26 May 2015, 12:16pm
Lowered a bit. The rimmer block (which I think they get from canleys) is a tight fit:
It needed a bit of persuading with the persuader.
But got it in the end. Eagle eyes may notice one less leaf. It's a guess, but from others comments on the rear being a bit stiff. We'll see how it goes.
26 May 2015, 12:20pm
love the two tone chassis - hadn't noticed that before
26 May 2015, 12:33pm
The grey is an impact resistant thick plasticky paint I put underneath to protect the powdercoat from stone chips. Looks alright too!
The tyres are 175/70R13 and don't foul anything even on full lock.
t
27 May 2015, 9:05am
I'm not going wires like most of u blokes just the original steelies
27 May 2015, 9:28am
Snap... I have white walls too, mines not a race car.
27 May 2015, 9:37am
Joy of our cars. I am going for wires for that "50's race look", but I know they are rubbish in reality.
27 May 2015, 4:22pm
1iTim - I like the look of painted steel wheels & shiny hub caps & think GaryH's look good too. :cool:
My donor car came with brand new alloy wheels and tyres, so I am simply sticking with them for now.
Do you have a map view of your container, in the same way you can track a plane on its flight path?
27 May 2015, 8:49pm
Do you have a map view of your container, in the same way you can track a plane on its flight path?[/QUOTE]
Yes Paul (and thanks, too! I may go mini lite eventually but I want to see the results with the coloured wheels first)
29 May 2015, 6:48am
I think removing one leaf may be a good idea for ride quality, just keep an eye on the Swing Spring as it settles, as mine is already a bit lower than when I'd finished and Towed found a great photo comparison of my Sammio build with the new spring fitted and then after 12 months and the height difference was quite visible!
Love the veined drum brakes btw! :)
29 May 2015, 9:16am
Thanks Dave. I'll certainly not throw the leaf away! And thanks about the drums- not many people can saw their car has the pinnacle of brake technology on the car! (Drum brake tech, sure, but still the best and way cool looking) also with "settling in" anyone who's taken the rear hubs off please check the nut at 5 and 10k miles
30 May 2015, 8:03am
Tuning video on utube Sounding pretty awesome. But eventually will need a muffler...
Now it has GV needles (quite lean) in the hs2s with tubular exhaust headers, as the hs2 DD needles were too rich. My father in law is the expert in the vid.
http://youtu.be/kz5mNoon5xM
30 May 2015, 11:13am
1iTim - Your car sounds like a motorcycle! :eek:
Jokes aside, I'm looking forward to the day when I can get my own engine running again.
The cargo ship tracking map is great. :cool:
30 May 2015, 12:44pm
ThAnks Paul, I'll take that as a compliment! Yes it is extremely satisfying to get it running again. And after my mods it runs and sounds better.
T
31 May 2015, 1:14pm
Thought I'd add that when I changed the 948 to closed crank breathing I had it routed to the manifold,past the carbies. It was sucking too much unmetered air (even with a 1.5mm restrictor) so I've rigged up a spare brake bleed nipple to go in the back plate of carb 2.
G'night
T
Pic of the back plate of back carb
11 Jun 2015, 11:31am
Hi all, could anyone please direct me to a section that deals with headlights and what we need to buy to put them in? I've got the bulbs from the herald but no longer have the bonnet.
20 Jun 2015, 9:58am
Chasing down a good state of tune for my 948 with a pair of hs2s. They came with DD needles, too rich. I put the GVs from the original herald h1s, still too rich. A bit of research showed there are different strength springs for the dashpots, and if the carbs are "on the large side" for the engine try a lower strength spring. So I've got the "blue" springs, and a set of CA needles which were a lean option to the GVs.
Blue on the left red on the right.
More info when I get a chance to fire it up.
17 Jul 2015, 12:22pm
Check it out everybody:
The fit is not as good as I have been led to believe (and forget about the included floors-not really fit for purpose.
The engine protrudes significantly and I still am yet to settle the frame and body to final height.
There is work to be done
17 Jul 2015, 9:14pm
nice to see that it has arrived, but that looks way out... Or is the angle of the shot?
17 Jul 2015, 9:41pm
You must have something wrong there , that's just not correct by a long ways , buddy.
Can you take some more pictures so we can figure whats going on ?
whats the fender to rim alignment like ? that might hold a few clues.
