Well good and bad today, bad becuase we didnt touch the Hindenberg in the end as a key snafu meant we couldnt move it......doh!
Good becuase it meant we could work on the Navigator...well sort of good, read on.
Firstly i managed to get my shiny new Weber mounted and the linkage all fitted and working, i needed to do this before fitting the body so i can check clearance under the bonnet.
Next we moved onto the front end, i had originally built one good rack out of two worn out ones that came with my donor package but have never been totally happy with it so now have a brand new one to replace it, nice easy job. Next was to fit the natty stainless front disc guards and the wire wheels to the front of the car, the passenger side went fine and ended up thus
Also managed to eventually get the right length fan belt which turned out to be 1025mm long, this is third go at getting the right size as my local factors listed 1050 as the correct length but i ran out of adjustment, it was returned and i tried a 1000mm one which i couldn't even get over the dynamotor pulley, third times the charm!
We then moved onto the drivers side front wheel which has aways worried me as it has never ran true, i had presumed i had messed up installing the new front bearings but further investigation showed that the stub axle is actually bent!
By removing it and mounting it in the lathe i had planned to use a dial gauge to see how far out it was, turns out a dial gauge wasn't really necessary grrrr
Just ordered a new one from Canleys so hopefully replacing it will see the chassis pretty much done and allow me to crack on with the frame.
