Garyh's Sammio build
12 Oct 2012, 8:58pm
adam1979 wrote:
Couldn't help noticing your blasting cabinet in the background - is it any good? I am thinking that will the amount of parts to be cleaned up, it might be a worth while investment rather than farming them all out to local companies. Certainly seems like that parts you've done so far look great!
It would also be a great excuse for a compressor - the ultimate power tool.
Hi Adam, it is very good. One downside is that the dust created inside the cabinet obscures what you are blasting but it does re circulate the media so you don't have to keep re filling the hopper... For the chassis I unused a hippo bag to trap the media, making it easier to collect and sieve, then re use.one thing I read that will stop it shooting everywhere is to use a fitting from a Hoover, the soft brush attachment. Seems like a good idea.
14 Oct 2012, 5:42pm
Chassis is now POR'ed, and i thought i would see what the top coat looks like.
Next Sunday i will undercoat and continue cleaning parts.
14 Oct 2012, 6:23pm
I bet seeing just one part in red gives you a real sense that progress is being made. :cool:
You have spent a lot of time getting the chassis right & I'm sure it will look great in colour.
Looking forward to seeing this come together, Paul. :)
14 Oct 2012, 6:30pm
Yes it does Paul, sometimes you just need to see a part finished... I have all new doughnuts, bolts etc... But I must concentrate on trying to do things well. I am looking forward to making the floor pans and bulkhead.
14 Oct 2012, 6:51pm
Hopefully you've bought some good donuts, there are a lot of bad ones around and if they split the failing drive shaft can do a lot of damage!
The advice on the Triumph forums is not to use the pattern versions even though it's very tempting to do so. On the Rimmer Bros site, genuine donuts are £186 each rather than £33 for the pattern! That's why Canley do a CV joint replacement shaft (very expensive!) and various people have engineered their own. Apart from any other considerations it's much less prone to vibration.
Some (like the Canley conversion) use the original hub and bearing.
http://www.tengaston.plus.com/Vitds1.htm
Others adopt the Rover 100/MGF bearing and hub
http://www.gt6.ca/josh/cv_rotoflex.html
14 Oct 2012, 7:31pm
I know you make sense M, but I will stick with the doughnuts for now. If they last a thousand miles... That may well be a couple of years. If I were to change, I would go for Canleys solution as its all sorted.
15 Oct 2012, 8:08am
I love the sight of painted suspension in the mornings.
Great job.
28 Oct 2012, 8:21pm
Chassis now has coat of red oxide as well now, next week i will give it a second coat. Unless someone says that is no t needed?
Can't wait to see Ruby Red topcoat.
28 Oct 2012, 8:47pm
Lovely. Something very satisfying about a bare primed chassis. Well done. You must be pleased.
28 Oct 2012, 8:49pm
After all this time, its nice to see anything other than rust... what was the moedia that you use for shotblasting, Ox?
28 Oct 2012, 9:17pm
JBlast aluminium oxide - I think it was supafine but I will have to check. I bought it from Frosts.
4 Nov 2012, 12:34pm
Fibreglass body
Am I alright leaving the shell outside all winter if I cover with tarpaulin? I see Paul has to keep his car outside, are there any other issues to cover...
4 Nov 2012, 5:28pm
Chassic looks great, its the only way i think, it hard work , but the day you want to sell it, you can add another grand on the price as this is what the customer wants to see.well done
4 Nov 2012, 6:41pm
Thanks Mike, I won't sell it... My wife has promised it to our daughter when she gets married... Hopefully I will get a good ten years of owning it.
11 Nov 2012, 8:13pm
I decided to get some bits shotbasted as i was getting frustrated with the speed at which i could get stuff done... £120 got my 4 wheels done and most of the suspension parts, enough to see me through to the new year. It means that i can hopefully have a rolling chassis by the spring. I did spray some of the topcoat on this afternoon, but it was going a bit wrinkly... is this because it was to cold?
11 Nov 2012, 8:26pm
I like the colour, and I love the look of blasted and primed parts.
11 Nov 2012, 8:32pm
Its the way they start off rusty and it comes up so clean... and a bit pitted!
11 Nov 2012, 9:47pm
Hi Gary,
Looks like getting someone else to blast the parts will save you time in the long run.
Sorry can't help you with the paint question, but I'm wondering about the temperature outside myself.
I was also hoping someone would have answered this question too...
It might be worth asking on the "Ask Mike" thread here.
So far, I'd say my light blue gel coat has faded a little, but not much.
And for a while the fibre glass was out in the open with no cover at all!
( The cover was on the rolling chassis and frame work. )
19 Nov 2012, 3:23pm
I am thinking of fitting an MX5 engine and gearbox due to the cost of rebuilding and i need a new head as i broke the corner off... Any thoughts?
19 Nov 2012, 3:41pm
The gearbox is quite big and very long. The engine is also pretty tall because it's DOHC rather than pushrod.
You won't have my starter motor clearance problems as it's top right of the bellhousing and on the engine side. A standard MX5 prop is the right length where I've got me gearbox and would just need an adpator plate to fit the diff. It's possible to move the gear lever forward about 4 inches if it's a MK1 type like mine.
19 Nov 2012, 4:01pm
It is a MK1 MX5 Eunos Import 1.6, can i leave the chassis alone? Or what about a 1.6 LITRE 711 CROSSFLOW XFLOW?
19 Nov 2012, 10:00pm
I put a tuned 1700 X-flow in the Herald chassis under my Moss Roadster with no problems. It was so long ago that I had no difficulty in finding the close(er) ratio 1600E gearbox. Twin 40 DCOEs kept the height down.
My V6 is sitting over the front crossmember (sump modified to fit). I've got plenty of clearance in the centre of the bonnet, it's the outer edges of the cam covers that are tight. I don't know the dimensions of the MX5 engine, but it is tall and I think actually longer than the V6.
