Dual 7" Servo
6 Dec 2011, 9:50pm
Update list
Jason
Is your PM working?
Can you add:
Andrew Curtis & now Marlin to the list.
I believe this only leaves one servo from the 12 zinc units unallocated.
They're going quickly............................
7 Dec 2011, 12:45am
Mike. Some thoughs about your forum post #195
1) While researching a brake upgrade for my classic (front drums to discs) I have found that the braking ratio for road cars is usually set at 65% Front / 35% Rear.
2) Unless the front / rear ratio was way out at original build then the improved servo should not worsen the tendency for front /rears to lock first, only get it to happen with less pedal effort / sooner?
3) When Jason did his road tests did he notice any tendency for fronts or rears to lock first?
Re your post #197: I will be using my car (Hunter) through the winter but due to other planned jobs it will likely be end Jan before I get to test the servo on the road. Peter.
7 Dec 2011, 8:59am
Mike wrote:
Jason
Is your PM working?
Yes. Saw it last night, but SWMBO decided I needed to do other things. Done now. :)
As for questions on locking, I don't know which wheels locked first... All I know is I started to slide.
That said, I know that at IVA, on the rollers the fronts locked before the rears, so she passed. The master cylinder hasn't changed, and neither has any of my brake lines or routing - so the bias will be exactly the same. Only the level of assistance has increased.
If people want me to do further testing, I may need to ask for contributions to a new set of boots when I flat spot them. :lol:
7 Dec 2011, 9:09am
This makes a lot of sense to me, and is quite reassuring that we should not have bias problems.
Jason - did you hang your head out the side and have a look ??!!
Oh no! Who is going to be able to give the first corroboration of Jason's findings? I know several of the other guys plan / have their cars on SORN over winter.
7 Dec 2011, 10:48am
Does THE STIG make such demands?
7 Dec 2011, 10:53am
Some say that he keeps lists of brake components up to date for fun... And that he like the smell of burning rubber in the morning. All we know is he called The GOO.
7 Dec 2011, 12:36pm
Another order
OK "The GOO"
Another update.
Can you add Alan Hogg, who has confirmed an order, to the list for a complete kit.
That now means the initial order for 2 + 18 is all allocated. So that is good news - Thank you all for committing - it now makes placing the main order very easy, and safe (commercially).
If we get any more interest I would like to keep it in multiples of 6, as the more people who have them, the less others there will be to take up any spares.
Unless of course MBM will send some more "samples"...........?
7 Dec 2011, 12:53pm
Alan added to the list.
And on that bombshell... ;)
7 Dec 2011, 6:51pm
Master Cylinder Diameter
Mike wrote:
Guys
I don't know if any of you looked at the specification figures for the boosters, or are even interested in the numbers, but I have made some calculations based on the data given by MBM, which show a very interesting result: see if you agree with the following;
My brake details are:
Pedal centre to pivot centre 32cm - excuse mixed units - it does not matter
Pedal connection to servo to pivot - 8cm
Therefore my pedal ratio is only 4:1
My master cylinder bore = 22mm = 7/8" = 0.6 sq inch
Now assume 23” of vacuum and 100lbs of applied foot pressure for comparative purposes.
Based on my brake's details:
[edit: it will not hold spaces to make figure line up below]
Booster size “Manual Pressure” “Free Pressure” Total Brake Pressure
7” Metro 666 psi *1 587 psi *2 1253 psi
7” Dual 666 psi 815 psi *3 1481 psi *4
*1 = (100lbs x 4:1) / 0.6sq.inch = 666psi
*2 = Metro booster constant 352lbs / 0.6 = 587psi
*3 = Dual booster constant 490lbs / 0.6 = 815psi
*4 - The dual offers an increase of 18% of the total over the Metro. This does not sound too impressive.
I then considered if I reduce the distance of myservo connection to pivot by 1.6cm to 6.4cm
The new figures are:
New pedal ratio is 32/6.4 = 5:1
Same master cylinder bore = 22mm = 7/8" = 0.6 sq inch
Same 23” of vacuum and 100lbs of applied foot pressure.
Proposed brake's details:
7” Metro 833 psi *1 587 psi *2 1420 psi
7” Dual 833 psi 815 psi *3 1648 psi *4
*1 = (100 x 5:1) / 0.6 = 833psi
*4 - The dual offers an increase of 16% of the total over the Metro, appears not so good
However, if we turn the calculation around to how much foot pressure is required to achieve the same total as with the original Metro, we see a significantly different result:
Original foot pressure to achieve 1253psi was = 100lbs
New foot pressure to achieve 1253psi = 52.4lbs *5
*5 = 52.4lbs x 5:1= 262lbs / 0.6sq.in = 438psi + 815psi = 1253psi
ie almost only HALF the effort
This has got to be worth a try!!
What master cylinder bores do you have?
What brake pedal ratio do you have?
Does anyone have a view on the calculations?
Not looked inside my master cylinder to check bore but raised number 23 on casting maybe 23mm? From Google I found the following DLJ website link
http://www.dlj-autoparts.com/eng/product.php?mode=list&cid=485
which lists several master cylinders including one of 23mm bore which is for a Mondeo! Peter.
7 Dec 2011, 8:53pm
I have a set of spare seals for my BMW master cylinder.
From measuring those seals, the BMW master cylinder is 19mm or 3/4" diameter.
I think that makes it better than the Ford version?
7 Dec 2011, 10:41pm
E=Mc2
I suspect your master cylinder is a part of your brake issue. Peterux has said his MC is 19mm. If you calculate the surface area of the two you will see his has 30% less area than yours, therefore the same pedal pressures in your two cars will produce 30% different psi at the brakes, assuming the pedal ratios are the same. The servo will be diluted in your car too.
I am not too happy either, as my Cabrio has a 22mm MC, which means 25% more effort than Peterux pedal pressure. This may well explain why Peterux says he could lock his brakes up.
I believe Jason has a Ford type MC, so it would be interesting to know what size MC he has, as he says he could not lock his brakes up, prior to fitting the Dual servo.
try dropping your own numbers in to the calculations I have made and see how the different sized MC makes a big difference.
Of course the flip side of a smaller MC is that the pedal will travel further to get the same brake pad movement. So it will be a play off between pedal effort and pedal travel.
Do you currently get very limited brake pedal travel?
Mike
7 Dec 2011, 11:01pm
Mike. From memory I don't think pedal travel was noticably short but the pedal effort required to stop was very noticable! I am thinking that the larger master cylinder diameter was fitted at POB because I have discs all round which theoretically may need more fluid displacement with eight large pistons? Can't do any practical checks at present as car on stands for smaller 24mm dia front ARB fitting (which has been on my 'to do' list for ages). Will do some measurements with and without engine vacuum when I can and let you know. Hopefully with a large master cyl bore I should get much improved braking with less tendency to lock the wheels. Peter.
8 Dec 2011, 8:22pm
Ah ha! Just realised I have the Teves type calipers with one piston on a floating carrier per wheel. So for eight pistons read four pistons total. Peter.
9 Dec 2011, 10:32am
Now assume:
23” of vacuum
Mike - Where did you get the 'constant' figures in the calculation?
I've tried to do the sums my self, but as a bear of very little brain, what little there is is now smoking. :)
Taking all the figures as stated, I got as far as:
666 psi Manual Pressure.
Metro Boost Ratio is 1:1.9, so total brake pressure is 666 * 1.9 = 1265 psi
Free Presure is then 1265 - 666 = 599 psi.
Then I get confused. I don't know the boost ratio of the dual 7"...
9 Dec 2011, 11:12am
Now assume:
23” of vacuum
Hi Jason
The servo generates a pressure by creating a vacuum on one side and allowing normal atmospheric pressure on the other. Therefore assuming your engine generates the 23" of mercury pressure (sorry about Imperial units, but just using the MBM assumptions), then the servo will always give the same amount of boost. It is not a ratio relative to pedal pressure, but a constant relative to diaphragm surface area - for a constant vacuum).
I calculated the constant from MBM's figures.
Surface area of a circle = pye x r2
1 1/8" bore - Sorry I need to convrt to decimal = 1.125sq.in
therefore (1.125 /2) x (1.125/2) x 3.14159 = 0.994sq.in.
Stated Free Pressure = 355psi.
Therefore the force from the servo was 352lbs
(352lbs / 0.994sq.in. = 355psi)
If you do the same calculation for the 1" bore and the 15/16" bore you will get a constant figure for the servo boost.
1" bore = 0.785sq.in
352lbs / 0.785sq.in = 449psi
15/16" = 0.69sq. in.
352lbs/ 0.785 sq.in. = 511psi
Therefore the servo gives a constant boost of 352lbs force. Note this is not psi, but lbs only. It is a force, not applied per surface area, until directed at the master cylinder plunger, and then it is affected by the bore size.
Hope this helps.
PS : The adaptor arrived in the post this morning - many thanks.
Mike
9 Dec 2011, 11:13am
Thank heavens for all you mathematitions, I will leave that to the intelligencia.
All I know is from what has been written so far is that the brake pedal should require a little less pressure to stop the car. Not quite up to my every day car standard but never the less better than it was.
Thank you one and all.
Dohhhhh, my brain hurts !!!!!!!!!!!!!!!
9 Dec 2011, 11:16am
Follow Servo Delivery progress
The servos are now in Lincoln, being held up due to a customs charge to be paid! This is despite asking MBM to send them marked as "samples" which should not attract a customs charge! One of them has got it wrong. But I beleive it is £28 which we should not have to pay on the overall delivery costs
I hope to sneak off early today and collect them this afternoon.
Keep your fingers crossed.
Mike
9 Dec 2011, 11:26am
Dennis
You are absolutely right!
Sometimes I wish I were not so inquisitive.
If you look at the ratio of boost between the 7" single and 7" Dual you also get a constant :
493/355 = 39%
624/449 = 39%
711/510 = 39%
And
The figures for the Dual are almost directly comparable to the 8" single
493 vs. 507
624 vs. 642
710 vs. 730
Put simply : The Dual offers almost 40% more assistance than the current Metro servo, and matches the Ford 8" servo as near as damn it, which we know from Chris Cussen, and Simon Gregory, works.
- All in all - it MUST be significantly better than before!
9 Dec 2011, 12:16pm
It will be interesting to hear if any of the cars experience that momentary feeling of the pedal being pulled away from your foot as the diaphrams "sequence", in responce to increasing vacumn as revs decrease.
This happens in a '33 Ford hot rod with a flathead V-8 I have driven.
9 Dec 2011, 6:03pm
Pedal Travel Check Marlin Hunter
Mike wrote:
Mike
Engine off (i.e. no vacuum /servo action)
Free pedal travel = 13mm
Total pedal travel with fairly hard push = 63mm.
Engine running at tickover
Total pedal travel with fairly hard push = 90mm.
Handbrake off for all checks. Peter.
9 Dec 2011, 9:01pm
New Servo Update
Good news.
The new servos have arrived, and certainly look good finished in Powder Coat Paint black. They are almost identical to the unit we tested, so I will go ahead with the main order on Monday.
I have posted pictures of the servo below, as this is your last chance for any changes of mind - would anyone like a powder coated one in preference to the ordinary Zinc unit for just £10 extra. I'd say it is certainly worth it.
The adaptor plate is a trial of one laser cut - the quality is superb. The universal plate will only have one set of holes to fit the servo. You can then drill yours to suit whatever angle your master cylinder requires. I'll get a circle etched at 70mm which equals the Metro/Ford fixing centres to make it easy to establish your drilling points. (or of course you can ignore it if it does not suit)
Unless I hear from anyone over the weekend I will order as per the list on the Forum.
With a following wind it is still possible you could have them for Christmas!
Regards to all
Mike
9 Dec 2011, 9:51pm
Mike wrote:
Good news.
Regards to all
Mike
Good news and thanks again for getting this organised!!
Interesting comment about being 'almost identical', so I assume the Dukesville unit didn't come from MBM after all? Any clues on the Dukesville unit as to its origin? Is it a 'far east' copy??
9 Dec 2011, 11:01pm
Hi Mike. If there is a chance I would certainly like to change to a powder coated servo provided it doesn't compromise the order quantities. Peter.
9 Dec 2011, 11:21pm
Hi Peter
I have had PMs asking the same from others, so I think we should be able to get what you want.
Given that Peter has put his head above the parapet first, would anyone else like to change their order to Powder coated?
I have to admit I would prefer the painted one to the chrome now that I've seen the quality and finish of the powder coating!
Regards
Mike
