I sanded down the edges, positioned it all with the bonnet closed and tacked it in place with some making tape leaving a few mm gap.
Once i was happy that it all looked right I filled the gap with bonding paste (there was tape along the back of the gap so that it didn't just fall straight out again!) and I let it dry overnight.
I removed the masking tape this morning and it looks a whole lot better!
Now that's all set in position tonight i'll sand down the back on either side of the new join and then add a couple of layers of fibreglass matting to re-add the strength. Seeing as it won't need to flex anywhere near as much in the future, this should resolve my cracking issues..... 'should'
Depending on how quick/easily that goes i will also be sanding down all along underneath the rear edge of the bonnet (where i had to extend it with filler) but leaving a thin layer of filler in place and then backing that also with a couple of layers of fibreglass matting that will join my extended bit to the original fibreglass bonnet giving that extra strength as well.
And as i am fed up of cleaning up filler dust from the garage that is the last mod i am making to the body work now unless something major drops off. It's going to be a case of
Once this is done all i've got left to do is repaint the fix, finish polishing the body and then it's on to the home straight of small, quick reassembly tasks:
- Tidy up around the front grill
- Refit the lights, bonnet straps, windscreen and number plates
- Mount the horns
- Add a bonnet 'stay'
- Wire in the instrument illumination lights as i forgot to add these and Pat says they're needed for the MOT.
- Fit the rubber floor ( i have bought WAY too much so i may end up selling some off)
- Screw in the wall and tunnel coverings
- Fit the seats, new steering wheel and new gear knob
- Get an MOT
- Wait for sunshine
- Drive!
And i plan to have this all completed in (all sing along now), a couple of weeks!
lane:
