Scottie's Tribute A352 build
14 Apr 2015, 8:08am
As Paul says, dont worry about making stoneleigh, your better off making next years and many years after with the finish you want, rather than making this years with a paint finish your not happy with.
14 Apr 2015, 8:24am
Yes you are right Danny, how bloody naive must I have been to have thought I could get it to Stoneleigh last year!!
I have seen so many cars at the show, spoiled by sub standard
paint jobs because the owners tried so hard to finish and get it there, promising themselves they would do it again later.
As you say, I want the finish I'm looking for first time.
This prep is so difficult for me, I do not want to go though it again.
14 Apr 2015, 9:06am
Scottie - do the prep work. I am currently deciding on whether to get mine resprayed or live with the blemishes. These are things that have surfaced since the original paint went on. Little ripples around the door handles where, I think, there was some filler shrinkage, a screw head showing on the bonnet and some rippling at the front of the bonnet where I added extra glass underneath and the heat of it going off caused the distortion.
All minor and most people don't notice but they scream at me every time I look at the car. You will see what I mean at Stoneleigh.
14 Apr 2015, 11:13am
Hey WCA, I thought you had it re-done by a pro? Remember when you rubbed it all down and it looked like a leopard?
14 Apr 2015, 11:44am
I rubbed it down and had it painted by a pro
The ripples in the bonnet happened after it was painted where I added extra glass under the bonnet to re-enforce it and the heat caused the distortion.
The screw head on the bonnet appeared before I re-enforced the bonnet and it was flexing a bit.
The door handles were put in by Chris but flexed a bit so he rewelded then and filled them. I then got those bits repainted but I guess either there was filler shrinkage or I didn't notice they weren't perfect before getting them resprayed.
So the first 2 appeared after painting because of the bonnet flexing and the last one was possibly because I rushed to paint.
Not a reflection on the quality of the paint job, but irritating none the less.
14 Apr 2015, 6:17pm
Hey Scottie, don't make the same mistake as me and use incompatible paints. My top coat has crazed like mad, I am putting off the weekend sanding it all back off.
14 Apr 2015, 8:22pm
That is my intention- my Z300S will be at Stoneleigh still in white gel coat with white primer in places and its try-out red stick-on stripes.
I'd rather be driving it.
14 Apr 2015, 9:08pm
Sorry to hear that Landmannnn, how come it was incompatible?
14 Apr 2015, 9:15pm
Another days labour, but as ever, there is a lot of improvement.
pics:
14 Apr 2015, 9:17pm
Not sure Scottie, just know it went wrong.
14 Apr 2015, 9:25pm
When you get reactions like that and not saying that it is the same but I had it went I sprayed an Alfa GT it was due to a reaction on different solvents. The best way to avoid any reaction at all is to use waterbased paint much less likely to have an adverse reaction. HOWEVER I am not a professional and have NOT painted hundreds of cars just a couple of handfuls and thus mine advise is from painful experience and mostly others advice.
If you do get a reaction there are two ways of dealing with it - sand it back to metal and start again (not my favoured route) or sand it back to smooth and seal it. you can get dedicated paint sealers or a trick I learnt was use a good lacquer.
15 Apr 2015, 5:50pm
Wednesday
I put in an awful lot of work today, but have been well rewarded for the effort.
Before I started to wet and dry the body, I had to put pipes on the two drain holes in the boot area, or the boot would get wet.
I can report that the drain holes work well!
I rubbed all the body down,then I decided to chuck some paint on it..
I am well pleased with the paint I chose for lots of reasons.
I like the colour, but basically it is an industrial paint, I chose it because it is fast drying, easy to apply, easy to polish, hard wearing, and has a very glossy finish. (I just sound like I have shares in the company!)
I intended to put on a "guide coat" to see what more work was required, and sort of got carried away.
When I saw how good the finish was, I chucked on the whole litre of paint,and did doors bonnet, the lot.
None of it is perfect, but fairly acceptable I think.
I will get another litre of paint tomorrow, and the good bit is, its cheap at only £25 for a litre.
I am certain that the "prophets of doom" will slag me off for using this type of paint, but look at the results, and judge for yourself.
If I'm brutally honest, the front half of the car needs a little more work to make it as good as the arse end, so I will sort it out.
Pics:
15 Apr 2015, 5:56pm
Looking FAB!............at this rate you be driving it next sunday.....
15 Apr 2015, 6:24pm
Excellent Scottie!
Looks very good indeed, sod the purists, I would prefer Celulose but I will be using Rustolium again AND a roller! :roll eyes: Why don't these emoticons work?
Well done.
15 Apr 2015, 6:28pm
That looks like a very good finish straight out of the gun unless the camera's lying. Is it cellulose? A link to where you got your paint would be useful Scottie.
15 Apr 2015, 6:39pm
Polish / sand / smooth the head light recesses. Mine are rough and it drives me nuts. Another thing to do before a respray.
Not nagging but yours don't look perfect either.
Gits to do because of the tight diameter so if you work oput a good way of doing it then please let me know
15 Apr 2015, 7:34pm
VERY impressed with your painting ability! and the colour you've chosen is very nice as well :)
15 Apr 2015, 7:36pm
Scottie - Wow!
As you'd run out of etch primer yesterday, I wasn't expecting to see BRG today!
Well it certainly looks like all your prep. work has paid off.
This really is going to be something special. :cool:
15 Apr 2015, 8:21pm
It's gonna be a stand-out car... Quick, put the seats in!
15 Apr 2015, 8:44pm
Great work yet again Scottie.. fibreglass is really not easy to get a good finish but thats looking stunning :)
15 Apr 2015, 10:10pm
that looks a really good finish Scottie well done, will look amazing when complete. really authentic.
15 Apr 2015, 10:39pm
Later Wed
Well, it seems my paint job has impressed more than just me!!
I am not very skilled at spraying, but this paint is amazing stuff.
To answer Mr Towed, no it is not cellulose, it is one-pack nitro-acrylic high gloss topcoat.
And yes, it came straight out of the gun like that.
And for anyone else interested, here are the details: it is made by Lechler,
and they say it is for restoring "old cars"
I bought my paint locally, at £20 plus vat per litre, but other companies seem to be charging £30 plus vat.
Here is a link : http://www.alloycoatings.co.uk/paintpainting-products-lechler-paint-lechler-mac-macrofan-topcoat-p-102.html
I think this stuff is way better than cellulose, and will use it again.
Like I said though, my car will need more work, as now I can see where I need more flatting, but I am looking forward to chucking more paint at it if it comes out like it did this time!
16 Apr 2015, 7:02am
Green - With Envy!
Scottie
That's an amazing finish, especially at the price and by a (self confessed!) amateur. If mine looks half as good with its mega-expensive Ecurie Ecosse cellulose professionally applied, I'll be more than happy!
Let's hope the weather's as good as this for Stoneleigh :)
Mick
16 Apr 2015, 7:27am
Wooow...what a big step forward! Well done! Can't believe you managed to get this finish with spraying it yourself! I am deeply impressed!! Can I bring you my car for a paintjob? :biggrin1:
16 Apr 2015, 8:41am
Sorry I've been trying to resist posting this, but I just can't. :rolleyes:
With full credit to Father Ted...
Scottie, this car is small.
And this car is far away.
:icon_wink:
