MartinClan Build Progress
15 Feb 2010, 7:13pm
Steering Wheel
Moto lita steering wheel. It's enough to make a grown man weak at the knees....
And the final install of the radio. The red wire is just a temporary "arial". Most of the other wiring will disappear under the carpet. In the end I fitted it on the rear "shelf". It was that or the boot. But being on the rear shelf means that at least I can get to it to put in a CD. (Albeit only when stationary).
15 Feb 2010, 7:37pm
Wheel = :rockon: :eusa_clap:
Looks the dog's danglies! :)
Any chances of some pics showing the adaptor plate? I guess it's just a lump of polished, machined metal with the 6 x 70mm holes interspersed with the moto ones...
15 Feb 2010, 9:22pm
It's a little more complex than that - but that is the basic idea. I'll try and poost a picture tomorrow. Mine is painted - as it matches better with the Momo adapter. (Also, the polished one is about another tenner plus then you would need the billet horn push which is about another £30) It adds about 15mm to the "height" of the momo adapter so in my case I didn't need a dished wheel. In fact the 14" flat wheel I selected is about right. I think a 13" would be too small. In fact I think you could probably even go for the 15" wheel.
The wheel itself seems to be well made. The wood is laminated. I reckon you could get a good match with some good quality mahogany or merranti marine ply. I too am thinking about replacing the door caps and dash eyebrow with a laminated wood version - but that'll be next winters project...
15 Feb 2010, 10:24pm
Ooo niiiiice steering wheel :D
The only thing I'd be a bit worried about with the radio where you've put it water getting to it :)
15 Feb 2010, 10:33pm
Only if you drive in torrential rain with no hood!
But you wouldn't do that, would you? :madgrin:
15 Feb 2010, 10:36pm
Robin,
That is a super wheel and goes well with your dashboard style. I think the grip will be good and the larger diameter will make the steering lighter when parking. Good choice!
...peter
15 Feb 2010, 10:53pm
I still haven't put drain holes in my doors.... makes for an interesting conversation piece. Now all I need is some goldfish :madgrin:
16 Feb 2010, 8:34am
I have to confess I hadn't thought about that. I guess that the cover should keep a lot of it out though. I already made up a new front plate to cover the area left when I removed the face. The main place where it is vulverable is at the back where all the connections are. Hmmmm - I may box that in completely. Then there would have to be several inches of water in thae car to be a problem!
16 Feb 2010, 7:41pm
Yer tiz.....
16 Feb 2010, 11:05pm
Ah - everything becomes clear. Looks like a nicely made piece, and not obvious that it's an adaptor once mounted, I guess. :)
17 Feb 2010, 8:43am
You don't even see it once the steering wheel and horn push are fitted.
21 Feb 2010, 5:56pm
I completed the "boot" today except for the top fixings which will have to wait till the tub comes off for painting. (Roll bar cross member in the way!)
I had a brain wave about the aerial. I used a £2 pillar mount job from Ebay but on a home made bracket that allows it to be swivelled down when not in use. Seems to work OK (in the garage anyway....) The bracket incorporates a couple of nylon washers to isolate the aerial from the body. I need to find a plastic clip to help support it when it is up.
Also had a play with the polishing stuff that I bought and the rattle can of Audi Amulet Red that I intend to use.
It's easy to get a mirror shine - but very tricky to get it consistent. I will have a go at one of the bonnets next weekend.
21 Feb 2010, 8:32pm
Coming along very nicely :) I really should make a lockable boot lid for mine sometime.
22 Feb 2010, 8:56pm
So I guess it's......
Aerial up - for cruising and listening to the radio
Aerial down - for high speed driving
:wink:
23 Feb 2010, 9:08pm
:wink:
Aerial up for radio control :D :madgrin: (I should watch less Mythbusters....)
23 Feb 2010, 11:23pm
Just as long as they get Grant to do the RC... Adam's rigs look a little 'Ghetto' most of the time. :D
24 Feb 2010, 8:17am
Did you see the one on Monday with the RC bus? - Awesome :D But it was an Adam rig so it failed horribly and needed manual overrides :lol:
24 Feb 2010, 8:21am
Yes - One of the best episodes of MB ever. Worth watching just for Adam's reaction when the rocket sled hit. :D
24 Feb 2010, 8:25am
:confused::confused::confused::confused: - I must be gettin' old LOL...
