Jag's 250SWBc build
28 Sep 2016, 7:04pm
JaguarTVR - Nice review of your experience of building a 250 SWB. :cool:
You have made consistently steady progress and I look forward to seeing it painted.
28 Sep 2016, 7:26pm
Thanks Paul, I just wanted to tell prospective builders to have a go. It's a very easy straight forward build and I feel that I have got to the point where a lot of people would now hand it over to a paint shop for final finishing.
Being a skinflint I will be preparing mine myself but will have the final paint put on by a pro. I will be posting details on the body prep, being sorting out the rear door gap today and am pleased with the result. Pics to follow.
30 Sep 2016, 1:37am
There was a post the other day on my thread by "Minehart" about my petrol filler and it has now disappeared and so has the user.
Any idea what has happened?
30 Sep 2016, 7:13am
Im still here
Unfortunately I know very little about building a car. I got Nubodi to build mine so cant contribute a great deal of info sorry.
30 Sep 2016, 8:54am
Just surprised that the post disappeared, didn't think it could happen. You had mentioned that I had cut the chassis to relieve the route for the fuel filler.
I came across this post
http://www.madabout-kitcars.com/forum/showthread.php?t=5192&highlight=changing+details
post 6
It seems to say that you cannot modify the chassis between the axles but anything fore or aft can be cut. I don't know if this is right or does it only apply to cars with a proper chassis?
Even if not I haven't removed anything, I have just folded it out of the way slightly and made good so nothing has been removed.
Does anyone know the exact rules?
30 Sep 2016, 9:09am
The rules are always as the authority decides at the time!:suspicious:
30 Sep 2016, 9:33am
Jag - as far as I know when I enquired when modifying my mx5 based "Roadster"
A Monocoque (combined body/chassis) can not be modified in any way without requiring SVA/IVA.
Anything that is bolted or screwed can be removed but nothing else.
Of course it is whether the examiner spots the modification, for example your cut rear panel for your boot. The Blackwidow SPR modifies the metalwork but passed an IVA.
I would think that the real time anyone would look so close is in the event of an accident and the insurance investigators will be much more thorough
2 Oct 2016, 3:01pm
Gapping the bonnet and rear door shuts.
The gap around the bonnet is excessive and the rear door shuts are rounded rather than nice and sharp.
I positioned the bonnet making the front and off side nice and tight meaning I would only have to fix 2 sides rather than 4.
I decided to go with 2mm gaps, not because I'm being clever, it's simply the thickness of the alloy sheet offcuts that I have. Simply fit them in the gap and hold them in place with some packing. Then push some GRP paste in the gap pushing it down firmly. On the corners I found the best thing was builders band again, just cover it in electrical tape to stop it fro sticking. Very easy to bend for the corners but too flexible for the straights.
When it has gone off lift the bonnet and you should see this.
The pink being the GRP paste. Remove the bonnet and apply a fillet of GRP paste with your finger underneath the bonnet to give it some more strength. I sanded everything with 80 grit first to give it a key.
I then went around the underneath edge with a mini belt sander to level it all up.
Trial fitted and the gap is great, just ran a long bed sander around the edge to level it all up.
Finally a coat of colour matched flow coat to tidy the underneath up, looks much better.
I will be using it on all of the underside of the bonnet and boot lid. Not as nice as proper paint but takes no time at all to do.
I now just need to get the front of the bonnet level before final filling on the top. The back is fine but the front sits too low, the two front pins are hard up against the GRP so it cannot be lifted any higher. Need to get my thinking cap on to come up with a work around.
Final gaps, just need to fill and contour the top surface.
The rear door gap was done in the same way.
2 Oct 2016, 3:45pm
Nice work - but if it's hard up against 2 edges with a 2mm strip in the other edges, does that mean the gap all round is 1mm? or have you also spaced the 2 other sides with the 2mm ali?
2 Oct 2016, 4:54pm
It looks the same all the way round but I'm not that fussy that I'm going to measure it!
Just been for my first test drive, nothing fell of but the grill is touching the fan under hard acceleration so will have to find a way to work around that.
Did get flashed and waved at from a Ferrari! Had too laugh, they are however 10 a penny around here as we have Marenello's at the end of the road.
2 Oct 2016, 9:40pm
Nice work. I've bonded in my 'inner' bonnet, but will leave a groove around the outside, so it will look OK. This has saved me all the hassle with catches/hinges and a rain channel. It also avoids the risk of scratching the paint if it's not hinged (when removing or replacing it)I'm also going for wider panel gaps, maybe 3mm.
3 Oct 2016, 7:12am
I think bonding the bonnet is is probably the way to go. I did see a 250 at a show, it had great paint except in the bonnet shuts, small point but my eyes went straight to it. I might paint the bonnet shut area first and then bond the bonnet in. Shame as the rear fittings work well but there is less room at the front to do the same.
3 Oct 2016, 7:16am
The bonnet is bonded in on mine and I'm pleased we did as the lines all look nice now.
3 Oct 2016, 7:47am
Looks like bondage is the way to go, I'll give the wife the good news!
3 Oct 2016, 11:35am
Bugger. Filled it up with petrol today and it took ageeeeees. No leaks but the pipe fills up with petrol so you have to fill it very slowly, it's as it the anti glug pipe isn't working.
On the positive side, it doesn't appear to be leaking and there is no petrol smell.
Been over to my painter and he has pointed out loads of extra bits that will need my attention, quite depressing. Hoping to get it into the oven for 40 minutes this afternoon, probably be even more depressed after that.
3 Oct 2016, 11:43am
A safe system is a great place to start any fixes from though. I guess a comparison of your panels with Jeff's (ignoring the other changes) gives an indication of how much effort has to go into this. Be sure to take pics of the car from all angles when sorted but before painting so we know what to aim for.
As has been said elsewhere, hats off to the professional preppers.
3 Oct 2016, 11:59am
Slow filling is something I've had to get used to. The main problem is if I forget to put a cloth around the cap and it then blows back petrol over the paintwork.
Oh how we suffer for our art!
Bob.
3 Oct 2016, 12:05pm
Is this just another male ageing symptom along with slow run-off?
6 Oct 2016, 3:17pm
Bonnet Gapping.
Have been finishing off the bonnet gapping and levelling. With the pates I made for the back of the bonnet it is possible to get it flush with the main bonnet. At the front one of the bonnet pins is to low so I cannot raise it up. Halfway along each side it sits about 5mm too low. I cut the font bonnet pin off, re drilled another hole and repositioned it. For the side adjustment I cut a 3mm plate for each side, drilled and tapped a 8mm hole so that I could use a bolt to adjust the height.
I drilled two holes in the other end so the GRP paste would grip it and I will go over it with some GRP woven tape.
Seen from the top
Having got the bonnet as flat as possible I filled the edges and flatted it all down.
Pretty pleased with the result. At the moment the way the bonnet is attached there is no adjustment, I just need to open out the two rear bolt holes fractionally and it will give me some wiggle room for final adjustment. I think 2mm all round is about what I will end up with.
6 Oct 2016, 3:38pm
Looking forward to seeing this tomorrow
6 Oct 2016, 3:58pm
Forgot the best bit, my inset bonnet grill, gives some real depth.
Set about 1cm back from the opening, it's commercial stainless draining mesh. £6.99 for a 30cm square inc post, I should get the bonnet and all 4 brake vents out of it.
See you tomorrow
9 Oct 2016, 11:37am
Reflectors, fog light and reversing lights
Have been pondering what to use, I like the rectangular Lucas reflectors that most people use but didn't want extra lights for reversing and fog light. I always think the ones that bolt on underneath look like a cheap 1970's accessory.
So cunning plan needed.
I bought 2 super bright LED bulbs for the reversing lights and an LED tail and brake light for the fog light.
Drilled a 5mm hole central to one side of the reflector, then opened it up with a 10mm and finally 24mm. This allows the LED domes to suck though the reflector but the metal surround won't go through so it acts as a stop. In-between the domes I painted the white surface by just dropping some red paint in with a cocktail stick. I then coloured the white domes with a red felt tip pen, this makes the bulb look red but when illuminated it shows white. One on either reflector for the reversing lights. I had bought a red LED bulb for the fog light but a tail/brake light bulb wired so that both come on proved to be brighter. I sanded the domes flat and then polished them back up on a buff.
I then glued this bulb to the back of the reflector after peeling away the reflector tape. I used a hot glue gun for the bulbs, LED's don't get hot so they should stay put.
From a distance you can't tell they have been modified. Not perfect but I'm happy with the results
The reflectors won't be very good now so I'm thinking of fitting some small mudflats with small reflectors on them. Now of course I'm fitting tacky 1970's accessories!
9 Oct 2016, 4:15pm
Jaguartvr wrote:
Bonnet Gapping.
Seen from the top
Good idea with the adjusting bolt . It might be wise to put a spreader plate under the bonnet where the bolt touches the GRP otherwise you might get star cracking in the future. GRP doesn't like being stressed with point loadings.
9 Oct 2016, 5:42pm
My painter said the same thing. I'm going to put a couple of slices in and put some GRP tape over the joins
