Nubodi automotive - Ferrari-esque Interior
15 Mar 2016, 7:21am
EL PRIMER wrote:
Nice to see some interior mods .
These are great looking cars , the finishing touches and details really help with the 'illusion'
The 'illusion' ? I i like the term 'Tributisation' :)
Great work Richard - thanks for sharing
15 Mar 2016, 9:04am
Still a long way to go yet though!
Being a convertible its more important than a coupe interior is I think, its all there with the roof peeled back its all on show.
I just wanted to show people that a good looking interior could be achieved under £500 by being creative and doing it yourself instead of paying out £3-5000 to a trimmer. I'm still on target at around £400 presently.
15 Mar 2016, 9:19am
I did mine myself , cost about £200 -£250.
Not a pro job but I take a but of pride as I did it myself :)
15 Mar 2016, 9:57am
Thats what Im trying to preach here
Pride in your own work (and save lots of pennies).
Was that including seats, steering wheel, stereo, speakers, carpet, basically, every non standard part in the cabin?
If so well done!
15 Mar 2016, 10:31am
That was for door cards, steering wheel (eBay) stereo (eBay) trim(eBay £40) got a friends wife to edge it, speakers (eBay) re coloured the seats my self .
It can be done if you shop around .
Most expensive part where door cards
15 Mar 2016, 11:29am
The holes were cut for the various furniture on the centre console and bolted on place (or will when the UNF nut set box arrives to match the chrome countersunk bolts...why not metric like the rest of the world! Grrr).
15 Mar 2016, 11:31am
Finally got around to bolting the drivers outer door handle on so I could then fit the driver side door panel.
15 Mar 2016, 4:38pm
or blow it just by fitting this itemhttp://www.classicferrariparts.co.uk/shop/ferrari-250-ashtray-2/:peep:
20 Mar 2016, 7:49pm
Okay progress will be accelerated as a show is looming. First jobs were on the black Rover 75 seats I'm using. I removed the headrests and filled in the resulting hole with black panel pins. They look okay for now.
The original Rover seat belts stalks were removed and the secondhand MG stalks bolted on. I put these on the inside of the runner not on the outside to give a little more room as the Rover seats are wider
20 Mar 2016, 7:57pm
The Z3 roll bar loop supports have always been an 'eye sore' on my Kalifornia so it was time to remove them. I got out the large reciprocating saw and started cutting around the base. It's not advisable to use an angle grinder unless you cover the plastic rear window, carpets, seats, etc. Unfortunately the blade was worn out and there was not any blades in stock, it was too late to go to B&Q so I had no choice but to cut them off with a hacksaw.
Two hours later...
You have to be very careful not to damage the hydraulic hoses for the roof or wiring loom.
20 Mar 2016, 8:00pm
I found some very smaller Pioneer speakers which were wired in and will hide under the carpet (hopefully)
20 Mar 2016, 8:02pm
The exposed metal from the roll bar loops was sprayed matt black to stop them rusting. The plastic surround that went around the roll loop and down the sides of the sear were cut down also.
20 Mar 2016, 8:06pm
In this picture you can see the roll bar support that was cut off. I had a piece of carpet left from a previous build and was the right colour (not black but dark charcoal).
This was secured by the same plastic studs that secured the original carpet up underneath by the back window. This is to cover the gap left after removing the plastics around the roll bars.
20 Mar 2016, 8:08pm
I then put the hydraulic roof down to press any slack out of the carpet before using two more studs to secure the next part of carpet.
20 Mar 2016, 8:14pm
I then spent all of the next morning coming up with a solution to the age old problem of getting a manual gear knob to work with an auto lock out. I found a solution which I will post separately as other auto owners from other forums and makes would like it.
Anyway the centre console was fitted with the ashtray (with hidden switches connected), gear and handbrakes leather gaiters and a new shiny alloy manual knob.
20 Mar 2016, 8:16pm
This evening I'm going to clean, treat and feed the leather Rover seats ready for installation. Oh and about an hour of hovering before they can go in! Still aching from cutting those roll bar supports.
20 Mar 2016, 8:24pm
It's coming on really well and very informative. I may 'borrow' some of your ideas.
20 Mar 2016, 10:13pm
I hope so!
That's why I'm taking the trouble to write it up.
22 Mar 2016, 10:08pm
Hi Bob
Sorry Ive been meaning to complement you on your build, it's just been manic, its looking great. The rear window trim is a donkey to fit right though...good luck with that!
Richard
24 Mar 2016, 7:47am
Quick up date on the clocks - I've eben dragging my heels but I've now got them finished along with the mask that goes behind and gives the illumination colour (red we've gone for).
Lockwood was over 200 quid for one off and came down to 70 quid per unit for small production run so not worth it.
I'm going to try and get these commercially printed over the weekend (so colour fast) and then get the mask bonded on then it's simply a question of cutting and fitting.
24 Mar 2016, 8:39am
Could the mask by produced as a vinyl printed sticker by one of the many sellers on eBay?
24 Mar 2016, 8:50am
Not sure if I should post this on a public forum but can I have photos of Richard knob please
24 Mar 2016, 9:24am
Its okay nick, I get asked this a lot. It seems my knob is in demand.
I will write up the modification this weekend in between shows (Friday and Monday)
24 Mar 2016, 9:52am
the mask has to be in perfect alignment with the main gauge print - there's quite a good online guide I found here which explains it much better than I can but basically the mask is only there to block out residual light spill and give colour to illumination when your lights are on - it's printed on a transparency.
Have a look at this guide - it's excellent:
http://mazda626.net/topic/39309-making-custom-gauge-faces/
