Paul Thanks
Today i started to mold the boot lid rain channel, after looking around to see what i had at hand to use as a mold i decide on some packaging that came with the steel plate ordered earlier which was used to run around the plate edge.
Made from polystyrene type foam its easy to bend and stick down and just so happens to be a good size.
Attachment “IMG_4673.jpg” from the original forum could not be reliably recovered.
Used a hot melt glue gun to stick the foam to the inside of the body, first marked a line around the boot aperture to use as a guide, cut a couple of nicks at each corner to help form a bend. Once the foam was glued in place brown parcel tape was applied to the foam to act as a release agent as you will see the area left to remove the foam once the fiberglass has gone off is narrow so the easier it is to remove the better.
Applied several layers of fiberglass working from the inside of the upturned body and using plywood covered in brown parcel tape to help keep a straight line and prevent gravity from pulling the glass out of shape. It basically made a u shape with a flat surface attaching it to the body if that makes sense.
Attachment “IMG_4680.jpg” from the original forum could not be reliably recovered.
A close up shot of one of the corner sections with the foam removed, had to gentle pick away at the foam with a Stanley blade and metal ruler, its also easier if you trim the height of the glass edge to give more access to the foam.
Will trim the glass edge further once the rubber seal arrives, i am using the edge seal from car builder solutions code #TRME, will also add a couple of piped drain holes as a good measure.
