Mister Towed on the road...
31 Oct 2013, 9:00am
Alpha wrote:
Don't want to be negative, but if the issue is indeed the lack of airflow through the engine bay (ie air in AND air out), a chin spoiler will not work...
It would be just like trying to force more water into a bottle that is already full.
Baz from Brussels
PS: the new tyres look fantastic!
Don't worry Baz, any advice is always gratefully taken on board.
I did wonder if I'd explained myself properly with the 'chin' spoiler idea. It's not going on the front but under the rear radiator to ram air into it at speed. I might even engineer a motorised or mechanical flap that lowers into the airstream dependant on speed and/or temperature, a bit like the engine cover on a 90's 911.
That way I'm hoping that the second rad won't over cool the engine in day to day dawdle driving, but will kick in at motorway speeds and stop the temperature rising too high. And because it will be between the back wheels it won't ground going over speed bumps.
As for bonnet vents, if you remember I actually have louvres at the back of the bonnet, but they're blanked off dummies at the moment. I could always grind out the remaining fibreglass behind them I suppose...
Nice to see your car coming together Christine, it's looking very nice indeed. How long before you hope to be on the road?
31 Oct 2013, 9:44am
Mister Towed, I think opening those louvres is the best idea yet and will
go a long way to solving your problems.
The D Types had them and had no probs at 170 mph at Le Mans!!
31 Oct 2013, 10:06am
On top of the obvious cooling advantages, letting the air out of the bonnet void will reduce the tendency for the rear lip of the bonnet to 'pant' at speed.
31 Oct 2013, 10:10pm
garyh wrote:
Won't that end up in the cockpit?
Hope not, it would certainly start a draft :whistle:
Just kidding. I won't block up the space between the bulkhead sides and body sides. Theoretically you don't need vents if the air can flow thru to the rear wheels. I'm not sure if plywood builds would benefit from this (venting/drying the wood and prohibit condensation) or ruining it (because of mud, dirt, spash/spray).
I'm using stainless steel and coated aluminium which should handle a variarity of conditions.
Michiel
1 Nov 2013, 10:11pm
I have watched with interest when you fella’s fit oversize wheels and tyres, and the result Is always an improvement on the original. They fill the arches and look good.
But one thing puzzles me, what do you do, to compensate for the extra rolling diameter?
The speedo must be out, and, to some extent the gearing, and if the wheel is quite a lot larger, The acceleration must be ruined.
Do you re-calibrate the speedo, or use a satellite driven one?
Do you change the gearbox ratios or back axle?
The most extreme example I can think of recently was Patoune on his D Type, he fitted 185 x 100 x 13 tyres, which would result in a whopping 21 % + increase in rolling diameter.
The acceleration must have been snail-like in the extreme!
No pun intended!
I understand he races them, so I guess he must have swapped the gearbox or back axle, or both.
If you’re reading this Patoune, please, what mods did you make, I’m really interested?
1 Nov 2013, 10:56pm
Hello Scottie,
I will use a different speedo. Not Triumph. I have it recalibrated as we speak. My car has 165/80/15 tyres. I had to measure the turns of the cable while pushing the car over a distance of 50 metres. They change the gears in the speedo. It will cost me about 100 pounds or so.
Michiel
1 Nov 2013, 11:09pm
That's interesting, which speedo did you use to do that?
1 Nov 2013, 11:15pm
Hi Scottie,
I beleive it is a BSA motor cycle speedo. Very appealing. it runs anti clockwise.
Michiel
1 Nov 2013, 11:54pm
Wow! I am impressed!
I will face similar problems later in my build, as I will use Jaguar dials, which will be miles out by default.
When I get to that point , I may contact you for some advice, as you seem to have it all under control!
As a relative newbie, is it "correct" to discuss this on Mr Towed's site?
Or should I be posting these type of questions on your build thread?
It is not my intention to offend anyone!!
2 Nov 2013, 12:10am
having judst returned frim the wicked carstle , I say salute you sammio builders and ribble and miglia alike for thouv art the true innovators and builders of great vehicular greatness. hoorah for sammio. the glorius leader is truly a pieoneer of all things magnifisent
2 Nov 2013, 12:15pm
Fpr speedo calibration try ETB Instrents
2 Nov 2013, 12:32pm
No offence taken Scottie, I'm not precious about this being my thread, I'm perfectly happy for it to be used as a chat room to discuss issues that are of interest to others when I change something during my tinkering phase.
As for how to compensate for the different rolling diameter of the larger tyres, a change to 175/80/14 tyres represents a 10% increase in rolling diameter over the 155/80/13's originally fitted to a Herald or Vitesse donor (not sure what Spitfires had).
As most speedos over read by around 8 -10% (a feature deliberately built in by manufacturers to ensure they comply with construction and use regulations) fitting bigger tyres on an otherwise standard drivetrain just takes out that error so your speedo is likely to be more accurate than when it was new.
I also fitted a 3.27:1 diff from a GT6 which obviously changes the gearing aft of the gearbox, where the speedo takes its drive from. As this would have made the Vitesse speedo under read by almost 20% I sourced a non-overdrive GT6 speedo to correct that error.
The result of those changes is that, when I put my car on the dyno with 175/70/14's, and the GT6 diff and speedo fitted, the speedo was spot on across the entire speed range, reading 110mph at a true wheel speed of 110mph.
My recent change to 175/80/14's will increase the rolling diameter by just under 6% over the 175/70/14's. This means that when my speedo says 60mph, I will actually be going 63.5mph. That's close enough not to get a speeding ticket :)
As for the acceleration being 'snail like' mine only has 79bhp but it's so light - lighter than a Lotus Elise - that even with big tyres and tall gearing it pulls like a locomotive in any gear across the whole rev range. It'll dribble along happily at 30mph in top and still storm away with a squeeze of the throttle, or you can scream it up to 45mph in first gear, 70 in second or 100 in third (on the Autobahn, of course) without even reaching the rev limit. Best of all is changing into second at 50mph when approaching roundabouts and listening to the spine tingling crackling and popping it does on the overrun :)
Good luck getting your Jag instruments to work, just remember, where these cars are concerned, as Yoda would say, impossible is nothing.
Here's a couple of useful resources for calculating all of the above -
http://www.kouki.co.uk/utilities/visual-tyre-size-calculator
http://www.mintylamb.co.uk/gearspeed/
Oh, and Phil just followed a modern car along at different speeds agreed with its driver and marked the corrections on the face of the speedo glass with a marker pen. That works too. ;)
2 Nov 2013, 1:24pm
Thanks so much for such a detailed explanation, really helpful.
When I spoke of "snail like" I was refering to Patoune's 21% plus increase in wheel rolling diameter, something that radical would surely wreck the accelaration? Especially considering it was a race car?
2 Nov 2013, 1:30pm
I should have added: as far as I am aware the "standard" Spitfire wheel and tyre combo was 155 x 80 x 13. Which would give a rolling diameter of approximately 22.76 inches, if that's of any use.
If you have a true 110 mph at that speed, that has to be better than a new car!! you surely have that sorted.
2 Nov 2013, 10:46pm
T, I forgot to ask, what does your car weigh please?
3 Nov 2013, 11:50am
It's 780kg's with a full tank. That puts it between the S1 Elise at 725kg's and the S2 at 860.
Even with my unstressed straight six only pushing out 79bhp that still gives me over 100bhp per tonne, and it feels quick enough on the road.
I do have a spare engine sitting in the garage that might just get upgraded when funds allow...
3 Nov 2013, 1:50pm
Mister T. That's really light for what you have, and what it looks like, no
wonder it pulls well.
When you look at the extra work involved to swap the engine for a few more BHP that you don't really need, is it worth it?
That will be the situation I will be in after my build. My donar is a 1971 Mark IV Spit, which should have had a 1300 engine in it, but has been fitted with a 1500, which looks new and sounds strong.
I am hoping to cut down on weight enough to end up with the car being no more that 600kilos if I get it right.
If I am successful, with the 1500 putting out around 70 BHP, I should
be in the same boat as yourself with over 100BHP per ton.
That should be enough.
3 Nov 2013, 7:38pm
Speaking of engines look what's just rolled into my workshop. :eusa_eh:
V12, 6lt, 300+bhp :love:
Just wondering what to put it in or rather what to build around it :heh:
4 Nov 2013, 6:20am
Well, a V-12 is basically the same length as an in line six, which is what the Triumph Vitesse and GT6 had, so it should fit any of the Ribble kits, no? :icon_wink:
Baz from Brussels
4 Nov 2013, 8:43am
Baz from Brussels
This is a bl**dy big engine, tall, long and wide plus it weights in at over 300kg so it would need to be sat well back in a Triumph chassis.
A Ribble's out but, one of Mike's Miglia's with that long bonnet and rearward seating :eusa_think: :eusa_think:
4 Nov 2013, 8:55am
I should imagine any Triumph chassis without severel upgrades is not going to be viabal. they are very thin wall chassis and rear axle , breaks etc will take a severe pounding
4 Nov 2013, 10:10am
first time your floored that in a triumph chassis it would turn into a pretzel!
Would make a nice table though :-)
4 Nov 2013, 10:15am
Probably best to install a bullet-proof shield between you and the diff unless you want to be fragged by your own car.
4 Nov 2013, 10:56am
600kg's shouldn't be too difficult to acheive - your four pot should shave around 100kg's off the total, plus I've fitted easily fifty kilos of fripperies, like a stereo, luggage bay, water injection system, servo, steel spreader plates under the seats, etc. Good luck reaching your target. :thumb:
4 Nov 2013, 10:57am
Haynes Roadster?
