9 Jun 2015, 8:48pm
How's the steering shaft (column)?
Steering Column to bearing link by marlinpeter, on Flickr
Air Inlet by marlinpeter, on Flickr
Possible Air Inlet solution by marlinpeter, on Flickr
Air Inlet possible solution by marlinpeter, on Flickr
Air Inlet clearance by marlinpeter, on Flickr
Washer bottle possible position by marlinpeter, on Flickr
Fuel pumps and filter by marlinpeter, on Flickr
High Pressure fuel pump by marlinpeter, on Flickr
Air Filter with cold air input by marlinpeter, on Flickr
Air Filter internal cone filter. by marlinpeter, on Flickr
Remote dual circuit brake servo by marlinpeter, on Flickr
M8 Rivnut / Nutsert tool by marlinpeter, on Flickr
Heater hose elbows fitted. by marlinpeter, on Flickr
Complete M50B25 Inlet Manifold Fits - Just! by Mike Garner, on Flickr[/IMG]
Air In-take : Revised - see later by Mike Garner, on Flickr[/IMG]
Inlet Manifold Fits by Mike Garner, on Flickr[/IMG]
Brake Servo mounting by marlinpeter, on Flickr
Fuel swirl pot or surge tank by marlinpeter, on Flickr
Fuel tank internal by marlinpeter, on Flickr
Fuel tank sender unit by marlinpeter, on Flickr
Fuel tank supply and return by marlinpeter, on Flickr
Fuel sender connector by marlinpeter, on Flickr
Fuel sender locking ring by marlinpeter, on Flickr
Fuel tank by marlinpeter, on Flickr
Fuel/brake line planning by marlinpeter, on Flickr
Fuel/brake line routing by marlinpeter, on Flickr
Fuel tank - trial fitting by marlinpeter, on Flickr
High flow fuel pre filter by marlinpeter, on Flickr
Air inlet bend by marlinpeter, on Flickr
BMW 1 (e87?) series pedal box by marlinpeter, on Flickr
Air box mounting bracket by marlinpeter, on Flickr
Spray booth? by marlinpeter, on Flickr
RH Fuel tank strap by marlinpeter, on Flickr
Diff oil change by marlinpeter, on Flickr
Fuel filter mounting by marlinpeter, on Flickr
Fuel pipes to tank connections by marlinpeter, on Flickr
Pre-pump filter by marlinpeter, on Flickr
High Pressure pump and filter by marlinpeter, on Flickr
Post Pump filter by marlinpeter, on Flickr
Rubber fuel hose by marlinpeter, on Flickr
Fuel pipes by marlinpeter, on Flickr
