I like the seats and the gearknob. Not too sure about the triple chrome bicycle bells on the top of the bonnet though. Are they for clearing errant pedestrians out of the way when you're driving it on the pavement?
I've just bought some rearlights, i have ended up with single light units hoping this will keep the back end uncluttered. I guess ther will be some sculpting etc...
Just a bit different from MG ones, these are from an austin wolseley
I top-coated before bushing - didn't want to get any Micha overspray on the bushes. I was very careful before putting bits near the vice - wrapped them up and used wooden blocks etc.
I have metal prepped the chassis to take the POR15 which i will do Sunday. I did a bit of shotblasting of parts and got some red oxide on them. Also had the old tyres taken off the rims ready for blasting aswell. I was intendin on having white walls, but i have been told that may mean having to have tubes.
If your rims don't have safety beads, then you should be running tubes anyway.
Couldn't help noticing your blasting cabinet in the background - is it any good? I am thinking that will the amount of parts to be cleaned up, it might be a worth while investment rather than farming them all out to local companies. Certainly seems like that parts you've done so far look great!
It would also be a great excuse for a compressor - the ultimate power tool.
When you've got the tyres off look for a hump inboard of each flange. Actually you don't even have to take the tyres off, just remove the valve cores and try breaking the bead (jump on it). With tube type rims the bead should break pretty easily unless there is a lot of rust.
Wheels for tubeless tyres have this hump feature so that the bead is less likely to come away from the flange resulting in a sudden complete loss of pressure (which you wouldn't get with a tube).
It might happen if you clip a curb in which case it's usually just very inconvenient. If your tyre pressure is low because you've not checked it or you've picked up a puncture, then cornering can pull the bead away from the rim and that can be very dangerous.
You used to see quite a few stranded caravans because they used the (cheaper to make) tube type rims for many years after cars had mostly moved to tubeless rims and someone had used tubeless tyres.
In theory a tyre fitter should refuse to fit a tyre to a tube type rim unless a tube is being used. Some rims have a safety bead only on the outer (more critical) edge which can lead to arguments about whether they're suitable for tubeless tyres.
Older wire wheels have to use tubes because they don't seal around the spokes, but some of the modern replacement wires are designed to run tubeless.
There is a further complication, some modern tyres are too rough inside and can quickly ruin a tube!
