Stewarts build
24 Dec 2012, 10:56am
nice fire but watch the loose fibre glass on these cars they make very nice tinder. As I:mad2: found when doing revised welding.
30 Jan 2013, 11:16am
Chose a simple job to be starting up again, Have been thinking about a wooden steering wheel but in the end opted to refurbish the original,
Chrome sprayed the centre spokes and stitched on leather cover, overall happy with the new look still looks classic, i hope
Pops
30 Jan 2013, 3:56pm
Long the wheel sir, did you stitch the leather yourself or did you have it done for you?
30 Jan 2013, 4:02pm
Wheel looks terrific 'pops, very fifties rocket ship. I also really like your instrument cluster, nice work.
30 Jan 2013, 8:24pm
The wheel cover was Ebay - £18, just had to stitch the seam to join it simple job - 1/2 hr or so..
30 Jan 2013, 9:55pm
The steering wheel looks both simple & effective. :cool:
It also works well with the steering column switches sticking out behind it.
What's next?
30 Jan 2013, 10:01pm
Very retro, and is in fitting with the look too, good work
1 Feb 2013, 11:31pm
A little more progress today,
Rear outrider cut outs completely glassed over and filled,
Dashboard underway, have formed a lip around top edge made from 8mm tubing sealed in place with filler then shaped and fibre glassed over,, instrument pod secured and taking shape, will be laying on wood veneer to give an original dashboard look if all goes as planned, trying to avoid the kit car image.
Tried my best to avoid any sort of bulge but the twin carbs left me no option
In true Blue Peter style heres how it went.
One Lemonade bottle halved
Then lined out with glass and resin.
After roughly marking the angle I wanted filled the shell with water
Sprayed in some paint (Silver was all i had to hand) dark would be better.
Once dried it leaves a line to cut out
The ridges and flat spot can be dealt with later..
Smallest cut out made.
And bulge started to be fixed and filled..both top side and under bonnet to be fixed for strength.
Will update on completed bulge once done..
Pops
3 Feb 2013, 11:42am
Now contemplating the electrics on my build, have replaced the original starter switch with a combined Lucas ignition on / off switch and headlamp switch.
this does not have the start function built in and so will have a separate starter button, my question - do I need to fit a relay as I see they come with car starter button kits, (mine is not a car starter button so comes with nothing).
Hope my long winded explanation is understood and someone can point me in the right direction..
Pops
3 Feb 2013, 1:09pm
For the first time in my life I have to admit to being impressed by a man's bulge. Really nice work.
3 Feb 2013, 5:17pm
Very neat solution. I like it. :)
3 Feb 2013, 6:50pm
battle of the bulge
Oxford glad your impressed with the bulge so far ,
Cheers Towed
Tidied things up a bit today filled and initial sanding to bring the bulge into shape
3 Feb 2013, 6:59pm
Perfect mate, great work
3 Feb 2013, 7:42pm
Is that a psychotic pop bottle you have used for a mould?:eusa_silenced:
3 Feb 2013, 8:12pm
I like the shaft of light (2nd photo) approval from above... He obviously follows your thread!
3 Feb 2013, 8:55pm
What him upstairs a petrol head
15 Feb 2013, 9:38pm
Hot stuff
Got the engine running and although pleased to hear it a little concerned as to just how hot the sports exhaust manifold is getting ..
Short vid taken in the dark .
And no thats not an infa red camera it really is glowing red.
Dont know if thats normal for a sports exhaust, maybe as its just stainless pipe and not cast, any ideas anyone?
15 Feb 2013, 9:50pm
Erm was that at tickover? If so I would suggest its running just a tad lean!
15 Feb 2013, 9:57pm
Yes it is tickover, havent adjusted carbs at all, waiting for timing strobe to set that spot on then will have a go at the carbs, I hope thats all it is...
16 Feb 2013, 12:43am
Who needs Colortune?
Great diagnostic tool you have there!
11 Mar 2013, 3:31pm
Managed to tune the engine before I left for work and pleased to say its a lot cooler, theres a faint glow but nothing like before,
Its easy to forget while I am away that temps are a bit on the cool side back home, maybe an explanation why reading matter has been a bit thin of late. Still I am seeing some progress from you guys just two weeks to go before I return and get some time in on the build myselfe.
Pops
11 Mar 2013, 4:20pm
Glad to hear you got the fuelling sorted, will hopefully start catching you up soon!
11 Mar 2013, 6:42pm
How long are you back for? Long enough to finish your car?
11 Mar 2013, 7:44pm
I work 28 home 28 away but doubt I will reach the finishing post next time ... But hope to be a lot closer.
Pops
