Monday
Bet you have aching hands Dave! Air power is the answer.
I have worked on the car most of the day and it really does not look much different, but I do feel I have achieved a lot, in fact I know I have.
Most of the "work" has been the 7 "p's"
Prior Planning and Preparation Prevents Piss Poor Performance.
I spent hours measuring, re-positioning the trans tunnel slightly, planning and scheming,and forming "cunning plans". Due to my car being 5 inches narrower than the original Jag, my handbrake had to go a little more in towards the centre of the car so's not to intrude into the passengers leg area, this has caused problems with the final top trim positioning, and of course made the whole job a lot more difficult. (Par for course on this build)
But I am used to this now hence the lengthy 7 P process.)
I think I now know how best to construct the trans tunnel so it looks right, and is reasonably easy to do.
Somewhere along this route, I decided to do something that the "Attention to detail" Gods had been demanding for a long time now.
I drilled 236 small holes in the bodywork. Yes two hundred and thirty six holes.
Starting to look like a Swiss cheese you may think?
Not really, as the holes were drilled in the centre of each fake rivet that the body shell came with. ( Not all the way through, just "blind" holes)
The rivets which I used to construct the centre divider and all the rest of the interior look right because they are real, and have the characteristic little hole in the centre, but the ones in fibre glass don't, and it looked a bit suspect and fake.
It no longer looks that way, and I think it was worth the effort. Once painted the drilled- out rivets will look much more believable.
It has to be attention to detail every time. Which I believe is the main difference between a believable car,and a hastily chucked-together kit car.
Very time consuming, but I think worth it for the difference in looks at the end.
I now have the wooden strips which will finish off the trans tunnel at the edges.
Here are some pics:
[IMG]
[/IMG]
[IMG]
[/IMG]
[IMG]
[/IMG]
[IMG]
[/IMG]
[IMG]
[/IMG]
