Hi Scimjim, thanks for the tip, but I read it too late!
Well the magnetic strip finally arrived, so I got stuck in and finished the job, then read the bit you posted about the tube hinge!
Sounds like a really good idea, which I most likely would have done if I'd read your comments first.
having spent what seems like an incredible amount of time pissing about with glue, magnets and bits of alloy, I eventually got to where I wanted to be.
At least it works, and perhaps a hinge may come later, but I doubt it!!!!
I seem to moan a lot about fiddly-arsed jobs, but I have to be truthful, and this was another one!
Also, I have decided to fit a main battery lead cut-off switch somewhere under the dash.
To those not in the know, unbelievably, the Spitfire donar I have used for my build, only has three fuses, yes three, not 8,567 like most modern cars.
(I think all Spitfires are similar)
By the time I have done all the connections to my new Jag-type dashboard, I would imagine the chances of a fire due to a short, and only three fuses would be a bit higher than I would like.
Apparently cut-off switches come in two main catagories, one with a removable switch, and the type with a fixed switch.
I decided to go for the latter, as the removable type switch would be just gagging to get lost, and then I would be stuck.
Well, stuck under the dash with a pair of wire cutters at least, not what I had in mind.
The switch has not arrived yet, but I will need an extension piece of cable to re-route the wiring under the dash, so I made one.
When the cut-off switch is fitted, I will have peace of mind, fire-wise, and a car that is bit more secure from theft possibly, so it won't be a bad thing to do.
[IMG]
[/IMG][IMG]
[/IMG][IMG]
[/IMG][IMG]
[/IMG][IMG]
[/IMG][IMG]
[/IMG][IMG]
[/IMG]
[/URL][/IMG]
