Whilst my daughter is much better, she spent another day off school today, so just a bit of car work for me.
Although I thought I'd start with the Wembley view of the partial Solar Eclipse.
I managed to carry on sanding down the rain channel edge so the boot lid rubber seal can sit lower.
I think this is as good as I am going to get the top edge.
As there is a little bit of distortion around both sides of the driver's hump.
( No doubt due to cutting the lid out in the first place. )
So this is something I will come back and sort out with some filler when the lid is fixed into position.
In order to get a best fit of the lid, I needed to make one adjustment along this panel gap.
You can also see that I've rubbed down some of the filler previously used to build up the around the top holes.
Actually I spent a bit of time making very small adjustments to other gaps around the lid.
Whilst any photo seems to distort the angles / gaps, this is the best view I can get of how the lid sits now.
I also managed to add some fibreglass filler around the top two holes.
Although my master plan of using my bolt separator to help me get a nice level failed miserably.
Thankfully I also got the chance to sand that down.
Then I decided to pop the locks in and have a bit of a play, despite the fact I still need to tidy this area up a bit more.
I could get the fixing bolts to hang freely below the locking pins.
So I used a couple of washers to mark the position underneath.
Which could then be viewed from above like so.
The spreader washers I made the other day just needed a minor trim to match these new holes.
Unfortunately my attempts to level these on a bed of fibreglass filler also failed.
So I will have to put a thin layer of filler over the top if I want these two surfaces to be level.
But I want to fix the locking pins to the boot lid before I go any further.
However, I need the new washers to arrive so I can double check the level of the top surface of the lid.
Then I can make sure the underside of the lid is parallel to that too.
I know this is a lot of work for something that should not be this difficult.
But I think I am slowly getting to the point where the top two locks will eventually work. < Touch Wood >
So until next time, take care, Paul.
