volvo p1800 into ferrari 275gtb nart spyder: v12, 5spd, tube chassis
17 Oct 2024, 2:26pm
Thank you!!! Yes I have been bad about updates. I'm sure I will have a big one for you shortly with some nice aluminum panels.
2 Dec 2024, 9:59pm
An update with a bunch of photos from my time spent in Mass. I feel like I really learned a whole lot, made some great looking panels, and came home with a lot of tool Envy as well. Wray was great and I really enjoyed spending time at proshaper learning his method.
unloading
learing the flexible pattern system for shaping
2 Dec 2024, 9:59pm
loading up to head home
2 Dec 2024, 10:25pm
Looks great! How long did you spend a ProShaper with Wray?
3 Dec 2024, 2:32pm
Thank you, 19 days.
5 Dec 2024, 4:31pm
I saw this pop up on face book over the last couple of weeks
Great progress
22 Jan 2025, 2:07pm
I took a little break but I'm on the ball again working first on the headlight joggle on the left side and then starting all the tipping and welding and planishing for the right side fender and nose piece. Having to upgrade some of my own hand tools along the way! A better wheel is definitely something on my must have list as well.
10 Feb 2025, 12:53am
Astonishing craftsmanship
10 Feb 2025, 9:52am
Yes, epic!
11 Feb 2025, 1:23pm
Thank you both!
4 Mar 2025, 1:18pm
I am waiting for my new E wheel to arrive to further work on the fenders and nose but I have been busy building the headlight buckets and side marker buckets to be welded on to the nose later on. Here are some photos.
31 Mar 2025, 6:03pm
Rt side fender vent is constructed. Had to make this little crude hammer with some bar and a piece of coil spring to get in that very tight corner. Now to do the other side!
3 Jul 2025, 12:32pm
I am long overdue for an update here! I've been all over the place working on different tasks.
I have been further tuning the front fender and headlight corner panels in the reverse area. I'm sure many of you noticed before it just wasn't flowing well. I took an angle grinder to the buck and some of the wires and tweaked it so the reverse can sit down more. It's about 90% there I think now. As for the fenders I still think I need to wheel a lot more in the top of the peaks of the to pump it up. It's just a little flat still. I'm also planning to add the crease line that runs along the peak of the fender from the a pillar to the headlamp bucket before the whole front is welded together.
I finally got to making the fender to cowl transition pieces also. I'm really pleased with all of that. I was scratching my head too much over it instead of just buckling down and going for it. Both side fender vents are now made too. The dashboard is pretty much finished off besides powder coating the frame and doing something about the padded top ( of course I can get it running without all of that though)! I made a little shroud to transition the steering wheel hub to the dashboard taking reference from some other vintage ferraris. All the major chassis electrical systems now work as well. Lighting, HVAC, gauges, horn, hazards, turn signals, electric steering, wipers etc. and I really tried to tuck all the wiring as much as possible underneath the dash.
I have realized some major changes will need to be made to the nose grill opening area as it is just not accurate to the real car. I'm thinking using steel tubing to make the perimiter of the grill opening and work off of that and I can also use it as a hammer form to some degree. There's a test panel to show you where the nose really needs to extend out to. If anyone else has more creative ideas on that let me know!
4 Jul 2025, 9:23pm
Love seeing your work. I pretend to myself that I would like to have a crack at something similar one day but know that i just don't have the skills, patience, room....but can dream.
6 Jul 2025, 1:47am
Thank you JG! I don't have most of those things, but I'm trying and learning!
11 Jul 2025, 9:21pm
I absolutely LOVE this project!!! Best thread on the forum!!! Keep the updates coming 275NART. You're an inspiration to us all!
30 Sep 2025, 6:59pm
Image hosting site imgur have blocked the UK from displaying any images hosted by them because of the new Online Safety Act. As a result its ballsed up great build threads such as this one where images the poster hosted on imgur no longer display if you are viewing from the UK. Well done this government, great job :headwall:
8 Nov 2025, 4:31pm
Canadian VPN works
8 Nov 2025, 5:50pm
A three-letter word doesn't do this justice, but WOW.
6 Dec 2025, 10:07pm
Well I haven't gotten to the grill opening situation yet, I keep getting side tracked going one step forward and several back. I decided after looking at the car and studying photos the headlight opening was just not correct, the shape or the size. These things really look like fish bowls! Luckily I had the material to work with since I needed to go larger! I beat up the metal a little more than I like but I think I should be able to clean it up when it comes time still. Sadly I will have to make new buckets too...
Here's a good comparison- right side is now ammended and a pattern was taken and then flipped to the left side to match.
both fixed
6 Dec 2025, 10:07pm
And now for something I was really excited to work my way through. The cam tail/taillight panel with recesses for the lenses. I ended up making a simple little hammer form with 3d printing and flow formed them in. Not perfect, and there were a couple tears in the really stretched areas that were a bear to chase out and weld up, but overall really pleased! Making this panel revealed that I will have to make some changes to the wire form in the rear to match the real car, but not a huge deal.
proof of concept:
now on the actual panel (I have already wheeled it out and tipped all the edges pretty close). I pre-stretched the area to be hammered a little bit before annealing and then flow forming all the way.
6 Dec 2025, 10:35pm
Beautiful!!!
3 Jan 2026, 1:46pm
I used AI to come up with a hardtop design based on the rear 3/4 image. It also "finished" the panels for me. I really like the version with the rectangular non wrap around rear window.
5 Apr 2026, 3:14pm
I need to get a VPN as don't see the images anymore cos of the UK's new policies.
