Another shot of interest for all. I overlaid the cascu panels on the deon and found engine lid was spot on. Rear boot was some 3 inches or for those in metric 76 mm longer. However the front bonnet was some 18 mm, sorry 3 quarters of an inch, shorter!! A lot has been said about the droopy nose on the JHC /Deon so was the bonnet lengthened to fit or was the 206 slightly lower at the front??layball:
Hi all;
Interesting things lately on the forum! Congratulations to thecarbuilder for his new purchase and his courage in trying to build his dream car!, well done and keep up with it.
Just to add more info on this blueprint: this is actually the first chassis developed by Ferrari used in the 206 GT and the first series dino 246GT (L-series). Pretty sure of this.
By the refererence on the top left, I´d say it is an original blueprint.
Hey Ian, just re-reading your post from May. I hope you've made good progress with your CASCU /Deon project - though the weather may be closing in for you (its getting pretty hot here in NZ). Its probably not very relevant to your project but the comments you made back then talked about shortening the wheelbase of a 246 to suit the Deon whereas the Deon (or JH Classics DGT as it was originally) was taken from a 206 not a 246. Therefore all Deons are based on a lengthened 206 wheelbase to suit the original Lotus Europa. Now that my long summer holiday is nigh I might dust off my paper planning for a Dino replica project.
Ross
Not much doing!! Thought I'd update you all on my build. After much measuring and several wooden mock ups I've given up and decided to use one of marks dino chassis. My idea was to get a standard dino chassis and alter it to fit new /bespoke rear suspension while keeping the front as is. But then mark contacted me with some superb news.
For all those that follow the page Mark is working with a french guy who is updating the original chassis to take more modern/bespoke running gear but sticking to the original geometry. He is also working on producing some of the more hard to find pieces. The chassis redesign will use all the original pick up points for everything dino but should allow the fitting of nearly all V6 engine/gearboxes you can think of!! The first chassis should be started soon but the new cad drawings look great.
The new chassis build is progressing well and we will sort some pictures out soon.
We have learnt a lot about the original Dino chassis through this process and have therefore found out that the chassis blueprint that was posted above is from a very early 246 and is very different to the later chassis. Very few of the measurements are the same and this caused some confusion when originally doing the drawings. However this is all sorted out now.
We are now starting to get some parts reproduced so with a little more time will be able to supply a very comprehensive kit.
Here is a little preview of the new chassis design for anyone who has not already seen it.
The front suspension will remain the same as the original Dino but with our own wishbones and uprights. The rear has been changed to allow more space for alternative engine/transmission fitment. The suspension has been updated to allow this but the basis geometry remains the same.
More updates to come.
thecarbuilder246 wrote:
Hi All
