So I have gone and done it...
2 Apr 2016, 12:25pm
y cymro wrote:
Thanks for that. I have the those in my ebay watch list - I agree they do look good. May as well delete them!
I have these in my new shape shogun and they look the dogs. I know that does not help though.
2 Apr 2016, 5:03pm
If you are smaller than me then they may be fine :)
2 Apr 2016, 6:04pm
Anyone experience of re-stuffing the standard BMW seats to give more lateral support?
Other thought is to create some glass fibre seats by taking the BMW seat, adding padding where I want it, covering with plastic, a layer of glass fibre, another layer of plastic and then sitting on it to make a perfect fitting seat. After that you could mount it on the standard BMW runners and stick the heated seat elements under any covering you add.
Not sure how easy this would be but interested if anyone has ideas as I would like to lighten and lower my seats.
2 Apr 2016, 7:34pm
Spent the day flitting from one job to another, fitted the replacement exhaust which was a pain in the backside doing it! Whilst the car was jacked up I couldn't resist fitting the "new" wheels, the last time they were all fitted the front wasn't lowered yet so I was intrigued to see the overall look.
After that I refitted the interior A pillar and header rail panels, mainly to get them out of the way so I don't damage them. Following that I fitted the rear screen just mainly to minimise the amount of dust entering the car during the what will be quite a long task by the looks of it.
Then it was time to get started on the body work, started with sanding of the door swage line and it also required at the end of the day another fill in places. Got the first fill on the drivers side rear body join with fibre filler.
Whilst all that was going off I got the lights refitted too, good news later on I started the car to turn it around and all the lights still work.:eusa_angel:
Last job to tackle was the boot lid lock, got it all measured out and cut the hole out and found the screws were too short to get through the lid fibreglass. Will have to buy some new screws tomorrow as only temporarily held on with the only screw I could find that would fit.
The compulsory pictures
2 Apr 2016, 9:40pm
Just another picture to show the wheels, no spacers fitted at the moment the front are good I like the rear BUT should I fit spacers or wait until the last point after paint to decide ?
2 Apr 2016, 9:42pm
I'd fit the spacers 15mm?
3 Apr 2016, 6:11am
Jones – Looking good. :cool:
Even if you are still a long way from final paint, just getting the whole car in grey primer will make a big difference.
3 Apr 2016, 7:42am
I drove mine around in primer for ages .
3 Apr 2016, 7:18pm
Thanks Roadster the jury is still out, if I do put spacers on they will be 25 or 30 mm on the rear.
Paul, thanks it has seemed to have accelerated a little now and I have some of my genuine enthusiasm back too. With regards to paint, yes I am far, so far away from that. That leads me to Drummajor, it is my intention to drive it quite a bit just in primer to ensure all is well and good before final paint.
Today I grabbed a few hours but due to the time of day I had to make due with keeping the noise to a minimum as it was still morning and we quite like our neighbours so I felt it best to leave the power tools until after 12 noon. Decided to refit some interior trim not because I think I am at that point but now the roof is on permanently I felt it would be safer for the trim to be fitted rather than lying around the very cramped garage. Fitted the rear side panel that to a while as had to trim out the space for the roll cage mounting point. I refitted the rear view mirror and the sun visors.
Next I sanded off the high points from the initial fill on the sides and finished off the door swage line. Laid down a some etch primer followed by a few coats of high zinc content primer on the lower half where I had taken down to bare metal. I followed that with a couple of coats of primer across the whole.
I mounted the new wing mirror too, a little bit more retro. :eusa_angel: just before I wrapped up I managed to get a quick skim layer of filler.
A few pics...
4 Apr 2016, 5:56am
Looking absolutely brilliant! It seems your build is very similar to how I intend to do mine! Can I ask what you used as the "template" for your fuel filler recess?
In regards to seats, has anyone got any experience with the standard "mini bucket seats"?
https://www.ebay.co.uk/ulk/itm/151253326936
That sort of style?
~Tyno
4 Apr 2016, 7:34am
Hi there,
I have two of those that I am not using (another eBay purchase after which I changed my mind). They are quite narrow. I am not particularly wide in the hip but I wouldn't want to drive far if I were using them.
One is in good condition - no marks or tares. The other was torn so I stripped it to look at the frame to decide whether I could do something with them.
PM me if you want any further info.
4 Apr 2016, 11:56am
Thanks Tyno glad you like the build. The filler cap recess was a pain to find the right size mould. You probably have read elsewhere that people have been lucky to have a paint tin or flower pot the right diameter, I unfortunately was not so luck. I had turned over the garage and the kitchen, and it was in the latter I found joy, it was actually a cardboard ring that came as part of the packaging for our new pots and pans. I made a cross insert to ensure that it stayed perfectly round and cut out a base in car and covered the whole lot in silver insulation tape I had left over from laying an underlay for our oak floor.
WIth regards to seats, I am curious too I have my eye on a couple of retro looking seats and a more modern equivalent variety too.
6 Apr 2016, 11:02am
Ah, I'll have to have a look once I've got the fuel lid on hand I suppose.
I'll be starting my own thread soon, as I've done some of my interior already in preperation for my kit! Will you be attending stoneleigh with the car?
10 Apr 2016, 7:44pm
Sorry for the abruptness but I just lost the first attempt.
tyno - not sure about Stoneleigh it was the intention and still is a deadline date to make it roadworthy. Get your thread started be keen to see your interior work.
So I had chores and other things to do this weekend so not as much achieved as wanted. I did manage to get the exhaust trim fitted properly it's a tight fit but the exhuast as a whole is a temporary solution in the grand plan.
Managed to wire up and fit the fog light it turns out the 'original' has been a victim along with many other must keep parts to the great 'get that car in a garage' quest at the end of last year. So this week I had to purchase another header/door seal only to cut it into pieces to make it fit. Back to the fog light, as you can see in the picture it sits quite low so will need a friendly MOT tester. It then folds away when not required for the other 364 days of the year.
Started the bodywork and this is where it went wrong for me today, I am not happy with the look of the haunches, I blended the kit to body well but the panel mould lines are slight out and as you sand, fill and shape to compensate for be another become an issue. Well see for yourself...
So the question is will I take this car to Stoneleigh? In its current state I wouldn't be happy to have so many judgmental eyes around it...
29 Apr 2016, 9:12pm
A while since I last posted any updates but I have slowly been making some progress. As I do want to have it on the road this year I am making some changes to the original concept but they can be reversed during the winter months if I see fit.
The first of those was to admit the hinge bonnet concept I have planned is on hold and for now I have reverted to using bonnet pins, although this was not as simple as I would have liked due to a work in progress corner I had removed some fibreglass that was the perfect mounting point for a pin! This is a must fix for tomorrow job, I did manage to get the other three completed this evening though.
Last weekend I had tackled the side windows seals and a bit of cut and shut, I know there was an easier way of completing the task as some have just sliced down the middle and then tiger sealed the two pieces back together overlapping the respective half's to reduce the depth. If I were to do it again, I would still do my method of removing the waste and fibreglass in it back together for a cleaner finish BUT I would have done this prior to final bonding as fibreglassing with a roll cage in the way was not easy! Plus the resin dripped too, a very messy job so messy I only could be bothered to glass one back in last weekend.
I did spend a bit of time filling and sanding but I didn't take any pictures of that.
Well that's it for now and probably see some of you at Stoneleigh.
30 Apr 2016, 8:08am
All progress is a step in the right direction. :cool:
I've spent quite a bit of time cleaning up the mess I've made with resin, bonding paste, filler, etc. :rolleyes:
30 Apr 2016, 10:38am
Thanks Paul - I have to admit without your 'honest' build thread showing the full journey and sharing all the thought processes and the good as well as the bad I might have taken a different route and posted a lot less. It has been the key for me taking on things I wasn't going to do on my first build or even show on the thread for fear of looking out of my depth.
4 May 2016, 6:29pm
Jones - Thanks for the kind words.
I've always appreciated the help and support I've received from the forum during my build.
Even if someone is politely pointing out I am doing something wrong. :rolleyes:
By the time you have finished you should feel rightly proud of your achievements. :cool:
7 Jun 2016, 8:55am
grinding out little progress
So not much to report - been moving very slowly just waiting on a few things to happen work wise and then I can move forwards a bit more again.
  • I have tidied up the wiring and encased it in a protective plastic sleeve
  • Repaired the n/s front bonnet mounting point that I had cut in my haste when I first got the kit to make room for the hinges that I thought I would be using - this idea has since been scrapped
  • Fitted the windscreen washer jets, albeit minus the hoses because some fool forgot to pick it up the other day whilst on a shopping trip
  • Done a bot more filling and sanding
  • tidied up the lower half of the n/s door, couple of zinc undercoats prior to primer - it has the made the primer coat lighter as you can see in the picture
I haven't been taking many pictures either so here's what I've got...
7 Jun 2016, 7:43pm
Jones - To the casual observer, it all looks good. :cool:
Note: I've left my OCD goggles in a locked box at the back of the garden shed. :icon_wink:
Thanks again for making the effort to drop by and say hello.
1 Jul 2016, 4:55pm
Not a huge amount of progress going on as it's crunch time on the new business but I have managed a 30 mins here on filling and sanding.
But whilst my free time has mostly been after the socially acceptable hours for making noise has past I have therefore found another way to entertain myself. It was always something I was going to do as a final touch but a post by another member prompted me into action.
New more period fitting dials were in order - I had a clear vision of what I wanted so it was a matter of booting up Photoshop and cracking on. Here is a glimpse of where I have got to today - can't finish it as I don't have the spray glue required but it gives you an idea. To be honest I am pretty chuffed with the results too. :smokin:
1 Jul 2016, 5:01pm
Can I quickly take advantage of the fact your online and ask you a quick unrelated question?
How much space is there to recess rear lights? I ask because I'm not ready to assemble my car yet, but I impulse bought some r33 skyline rear lights and was wondering how much space I have to play with to recess them in the rear panel
1 Jul 2016, 5:25pm
Ummmm lots of room behind where I have my lights but you might be limited the more you move inwards by the boot extension panel but not sure. I'll get out and have a look if you want measurements too. Mine is also a mk1 and the rear panel is slightly different I believe on the mk2 if you one.
1 Jul 2016, 6:05pm
They look good - can I ask what did you print on (maybe just regular photo paper)? and did you use an inkjet or laser printer?
