Mister Towed on the road...
29 Oct 2013, 8:09pm
oxford1360 wrote:
Do you think you might need an auxilliary water pump to help fluid circulate. BMW and Mercedes items might be appropriate. They go for about £25 on a well known auction site.
I'm hoping that the (new) Triumph one will do the job. There are no restrictions in the hoses, it's all going to be 32mm, so I've got my fingers crossed that it'll circulate just fine without an auxillary pump :pray:
29 Oct 2013, 8:17pm
Neat fit.
That's a large volume of water to push around.
An auxiliary pump and a shut-off valve might be a good idea otherwise getting the car to warm up might be a problem in the coming winter months. :idea:
29 Oct 2013, 8:34pm
micky1mo wrote:
Neat fit.
Both radiators are downstream of the thermostat so warming up shouldn't be affected. We'll have to see about the extra pump...
29 Oct 2013, 9:22pm
It looks quite vulnerable to being damaged down there?
29 Oct 2013, 10:37pm
Was about to say that a stone flicking up at 70 woold damage it...a mesh screen may have to come into play I would have thought?
30 Oct 2013, 8:27am
The older type of water pump is designed to circulate water not pump water, much like a spoon in a cup of tea. This is why its normally place in the centre of the mass of water it has to move ie; centre of the engine block.
Because of this (and past experience) I think your going to have problems :ohwell:
30 Oct 2013, 8:50am
OK, sounds like I need to do a bit of thinking then. Perhaps a secondary electric pump and a control valve triggered by a temperature sensor might be in order.
By the way, what do you think's likely to happen if I don't boost the circulation?
Oh, and I probably will also fit a screen to protect it from flying stones, just like I did at the front.
30 Oct 2013, 9:16am
I supect the volume of water in the system will be just be to"heavy" for the standard pump to move so you'll only get partial circulation and little heat transfer.
An air lock in the cooling system can cause similar efect because the volume of water is not equal either side of the circulating pump so no circulation.
Air locks might be another problem you have to deal with. :doubt:
What type of radiator are you running? is it an original 2lt radiator? can you not fit a better (not bigger) radiator up front, also a good oil cooler will help?
30 Oct 2013, 9:21am
second rad
Mister towed,
I was reading about your second rad, and the problems you are facing.
I read some of the earlier thread to see why you needed an extra one and I've missed something.
So why briefly, why a second rad? I'm really curious .
30 Oct 2013, 9:42am
Scottie22 wrote:
Mister towed,
I've fitted an aluminium radiator from a Honda Civic VTEC up front with an electric fan and in normal driving it's fine.
While running at motorway speeds for over an hour though, the temperature starts to climb rather alarmingly. It didn't actually overheat, but I don't really want to be driving it across Europe with one eye on the temperature gauge.
The problem is likely to be the amount of air being rammed into the engine bay behind the radiator through the large scoop in the bonnet. The scoop isn't cosmetic, by the way, it's there for the bonnet to clear the six cylinder engine. I don't really want a chin spoiler to drag more air into the rad, I think it would look terrible, and there isn't really anywhere to put an oil cooler that wouldn't obstruct the radiator, so I thought 'why not bung another radiator in the back?' as you do when you've built your own car.
It now seems that it wasn't such a simple idea after all, but that's one of the benefits of posting ideas on this forum, there's always someone who can give advice to stop you screwing up :hail:
So, as I've no motorway journeys planned until next year, job for today is to reconnect the original coolant hoses and leave the new rad dry mounted in the back while I save up for a Davies Craig water pump. :icon_redface:
30 Oct 2013, 9:51am
Hmmmmmm.
The things that spring to mind are:
A larger rad to start with
Bigger or twin fans, perhaps a manually operated extra fan
Alloy panels /ducts out of sight to channel air to where its needed
If the temperature rises like you describe, it would seem that the rad can't cope and it needs a bigger one?
Those would be some of the options I would consider, stood in your shoes.
30 Oct 2013, 10:41am
Overheating at speed
I've had another think about this, and something does not seem quite right here.
Usually, the faster you go the more air passes through the rad and the water temperature should fall, not rise. But in your case it doesn't.
Therefore logically something is wrong. But what?
Back to basics:
Buggered water pump, thermostat not functioning correctly, restriction point somewhere in the system, perhaps it is a simple, easily cured fault Mr Towed.
Perhaps someone reading this can offer some advice?
Come on you guys!
30 Oct 2013, 1:56pm
Just reading the pass few post and I think you should look at the "air flow" first.
Formula 1 teams found at speed a scoop creates cavitation around the edges and slow down or at least restricts the air flow.
I think at 70MPH the air is not all passing through but getting trapped and being buffeted around the engine bay keeping the heat in and over a period of time building up and blocking or slowing down the flow of external cold air.
I have known of a simple mess grill causing similar cavitation problems.
Are you using inner wings? If you are not try fitting them, if you are try removing them or cutting some vents in them.
As Scottie22 said higher speed should mean greater air flow and cooler running.:plane:
Hope this makes sense :icon_confused:
30 Oct 2013, 2:15pm
Mr Towed,
I have run your situation past my friend who is very well versed in this sort of thing, and what he said was: take the thermostat out and go for a fast high speed run, if the temp does not fall, he thinks you may have a head gasket problem.
This test at least would rule out the thermostat as the fault.
30 Oct 2013, 2:21pm
Guys, this is a well known issue with the donor cars (Spitfire / GT6) The issue is not getting air into the radiator, but getting the hot air out of the engine bay. In most conditions, this is not a problem, but in high speed running it does cause problems. That's why the Le Mans Spitfires had extra bonnet vents behind the front wheels, and the GT6 has extra louvres on top of the bonnet.
Towed, with your large scoop pushing extra air into the engine bay behind the radiator, it is not surprising that you have reduced airflow through the matrix...
Extra radiators and pumps will not help in this case
Baz from Brusels
30 Oct 2013, 3:51pm
Electric thermostatic fan blowing air OUT of the engine bay?
[edit]
Just looked back at pictures of your engine bay and bonnet and there are no convenient vents. Perhaps you could vent it out of the wheel arches?
I seem to remember the original Minilites were designed to suck air across the brakes. I am guessing sucking warn air across the brakes is not ideal so perhaps some flexi ducts (http://www.i-sells.co.uk/ducting-flexible-hoses) positioned at the top of the arch out of sight?
30 Oct 2013, 7:30pm
The supplementary cooling system will have to wait for another day now as it's not an urgent upgrade, just one that I want to make before I undertake any more motorway journeys, which won't be for a while now.
Another non-essential change took priority today as I had a pair of 175/80/14 tyres fitted this morning to replace two of the 175/70/14's I've been running.
You can clearly see the difference in diameter, the new size is on the left -
The reason for only ordering two is that I wasn't sure they'd fit on the front without further modification to the bulkhead, but I was confident that they'd fit on the back, so I could always run with the lower profile tyres on the front if I couldn't make the bigger ones fit.
To my surprise, they fitted on the front with no more fouling of the bulkhead than the 175/70/14's exhibited before I raised the front suspension. They just skim the bulkhead on full lock, but it doesn't restrict the steering or cause any judder. I took it for a test run for a couple of miles and threw it round a couple of roundabouts with no problems.
Here they are fitted to the front -
I then swapped them to the back as it looked a bit odd running with smaller tyres on the back than the front, and went for another test drive. Guess what, they fouled the rear arches during the roundabout test :(
You can see how little clearance they had here -
So, it was out with the rear spring, again, so I could remove the final 18mm of lowering 'shims' and put two of the recently removed intermediate springs back in for a slightly firmer back end (ooh, Matron!).
Before -
After -
And as Goldilocks would confirm the result is just right -
They don't foul any more and I've actually got some ground clearance. The taller side walls are more compliant and compensate for stiffening the rear spring while I'm pleased with the way they look, so I'll be ordering another pair for the front.
30 Oct 2013, 7:40pm
Mr T, I think the wheel/tyres and suspension is one of the greatest arts with these cars. :icon_confused:
Yours is looking good now and probably will sit at the same height as Phil's two. My Miglia will have no lowering at the back and 70mm off the springs at the front so should sit about where yours is now.
All part of the fun of ownership though! :icon_razz:
30 Oct 2013, 7:47pm
Cheers Tony, are you going with fifteen inch wires again or something different for your Miglia?
30 Oct 2013, 8:05pm
Yep 15" wires with 185/65 tyres.
They are a little chunkier than the standard wheel/tyres...
Initial try with the body looks ok
I need to trim the wheel arches - in fact I have started but a holiday and new kitchen for a friend got in the way!
I haven't lowered the back at all and when it has all the seats and interior, fuel tank etc it will settle a bit anyway so should be okay.
Hope to get on and do a bit more over the next few months if the weather stays okay.:eusa_whistle:
30 Oct 2013, 8:09pm
Have to say i agree withe earlier post T, the scoop on the bonnet is allowing air in and equalising the pressure in the engine bay against the air coming in the front of the bonnet, the result is a stagnant area in the engine leading to lack of flow through the rad, had this issue on one of our race cars some years ago, some good size vent holes on the sides of the bonnets should help or possibly block off some of the front of the scoop? We solved the problem by fitting a flat floor, rear diffuser and sone fancy ducting, might not be appropriate for you though :-)
Nice upgrade on the tyres BTW, you must be getting expert at "whipping your spring out"!!!
Mac
30 Oct 2013, 8:50pm
Hi Mac, spring out in under thirty minutes, a new personal best!
Spring back in in three hours, what a pain in the ar$e!
I agree about the scoop equalising the pressure in the engine bay. I don't want to block off the scoop or cut vents in the sides. The plan (now) is to plumb in the rear mounted radiator with an electric pump, and, now I have some ground clearance, put a chin spoiler type arrangement under it to scoop air in at higher speeds. Might even give me some downforce on the back tyres, very Fomula One.
Nice wires Tony, new chromes by any chance? You might want to take a leaf or two out of the rear spring to get the ride height right. I'm becoming a bit of an expert on changing the small chassis Triumph suspension now. :peace:
30 Oct 2013, 11:16pm
Don't want to be negative, but if the issue is indeed the lack of airflow through the engine bay (ie air in AND air out), a chin spoiler will not work...
It would be just like trying to force more water into a bottle that is already full.
Baz from Brussels
PS: the new tyres look fantastic!
31 Oct 2013, 6:36am
some venting like this?
31 Oct 2013, 8:38am
Won't that end up in the cockpit?
