Mr Bonds Build (Car noob)
29 May 2015, 8:29am
Looking good, I like the bonnet scoop and blister for some reason.
What's the slot across the rear deck for? Is it for the 007 style bullet deflector?
The finish on Mr Christmas' A352 was simply stunning, a credit to the chap who prep'd and sprayed it. Nice colour too, as chosen by the first billionaire to order a 'new' £1.2m Jaguar lightweight (Channel 4 documentary last night). Although Jaguar's hand picked spray chappie estimated around £40,000 to respray the bonnet if necessary, which is the equivalent of about ten quid to the new owner. Bargain. :(
29 May 2015, 11:15am
Yes what can I say. There will be a glass screen that lifts out. I'm hoping to make a hard top and the glass will lift up into this. I have made the frame and motor and it works with a mdf template. This will be changed for glass when I have figured out how the springs push two pieces of glass, to fit the two humps when it goes up/down.
Other ideas spring to mind!
29 May 2015, 1:01pm
Very Ben hur... pics of hood, sounds amazing.
29 May 2015, 3:23pm
froggyman
colour is going to be gloss white from Jarwel. I did look at silver birch to go with the bond theme. which I now regret as I did a sample piece on the car. I thought I had removed the paint but discovered after priming the paint reacted in a couple of places so I've had to rub one section down again yesterday.
29 May 2015, 3:42pm
Don't i get an answer, Mr. Noob!
29 May 2015, 6:08pm
The inside of the bonnet looks good, how did you prep the surface as it looks very smooth?
30 May 2015, 7:45am
Just kept rubbing down and filling .very time consuming
30 May 2015, 10:44am
CarNoob - Shame to hear about the previous test patch paint reacting. :icon_sad:
As it certainly looks like you have put a lot of work into getting to the primer stage & it all looks good. :cool:
Hope the rest of the painting goes without a hitch, good luck, Paul. :)
Your hard top idea sounds very interesting too.
16 Jun 2015, 7:22am
ebay £3.50 from China
side vents will have indictor lights in.
26 Aug 2015, 7:32am
Finally Painted Jawel Pure White Gloss, Just need another ltr to finish under the bonnet.
The back end really bugged me so I made a section and pop riveted to the bottom. Now nice and even.
lots of jobs on at home so I do a bit when ever I can!
26 Aug 2015, 7:50am
That looks great
All that prep and your loss of fingertips was worth it.
Did it go without a hitch?
26 Aug 2015, 7:56am
lovely work, it will be nice to see another colour being used... How does the boot open, are they push buttons?
26 Aug 2015, 11:33am
CarNoob - Congratulations on getting your car painted, the white looks good. :cool:
I like the section you added under the number plate, in fact, the whole back end of your car looks very "clean".
26 Aug 2015, 3:35pm
yes push button look on page six picture of one in hand. they fasten nicely :nod:
28 Aug 2015, 3:47pm
Roadster wrote:
That looks great
Painting went ok except for the test area I used a sample can on, so test some spray on some areas first. A friend did a complete re spray on his Lamberetta said it looked fantastic because of all the prep. came back 2 hours later the whole bike had a crackle finish:cry: . If anyone else is painting prep then prep again then when ready once more for good measure. Add extra thinners to the final coat. I used a 2 for the high build and1.4 nozzle for the finish next time final coat would be with 1.8 nozzle
18 Sep 2015, 3:36pm
trial fit for the dash side panel, still work to do on the removable carpet.
18 Sep 2015, 4:54pm
That all looks very nice. :cool:
29 Sep 2015, 2:46pm
Car now has lights. had same problem as you Paul, holes for indicator screws too close to the centre hole. Slipped with drill and chipped paint just above the light, small job but annoying.
29 Sep 2015, 5:58pm
Sorry to hear you also had indicator fixing problems. :icon_sad:
But getting the headlights fitted really does make a big difference. :cool:
17 Oct 2015, 9:40am
Maserati badge
<a href="http://s1354.photobucket.com/user/JPB007/media/Mobile%20Uploads/20151017_093734_zpsof5esky6.jpg.html"
19 Oct 2015, 1:54pm
Nice work on the badge. :cool:
Is it to the same scale as your cardboard mock up?
19 Oct 2015, 5:26pm
Yes size is about the same. Made a rubber mould today. I am going to cast in a two part resin plastic that is very strong, I may make another in aluminum. But first need to make a small foundry.
