Nicks Sammio Build - take 2
11 Jul 2012, 10:03am
you lot have WAY too much free time! :)
11 Jul 2012, 10:20am
oxford1360 wrote:
If you want to go for the aluminium-bodied racer style look you can always spray two coats of silver that are different shades (slightly darker one underneath). Then go at it with some wire wool and it will look like the BMW above...
It could end up looking like fifty shades of grey though and need leather harnesses instead of nylon... :tape2:
11 Jul 2012, 10:35am
Yep, sadly (?), out of work since December 2011 and awaiting G46. Been a little bit of a delay but hope to get my hands on the conversion soon.
In the meantime will start rebuilding my Honda Blackbird which I wrote off on Saturday on the way back from Fairford. As soon as the bruising goes down...
11 Jul 2012, 10:36am
But what would a leather harness do to your Salami though?
25 Aug 2012, 2:59pm
Woo Hoo! Picked up my body and frame today!
The guys at Tribute Automotive who did the body were great. Friendly, helpful and didn't complain when I turned up two hours early to watch and learn.
Just finished the mountain bike event so am going down the garage to play.
Photos later today
25 Aug 2012, 3:12pm
I will look forward to seeing your progress (lots of pics please). The twin humps look very good, much better than I had expected!
25 Aug 2012, 9:49pm
And it DOES fit on a pickup ..... Just :biggrin:
25 Aug 2012, 10:44pm
Best wishes and good luck with your new toy...
(Don't forget the respirator...)
26 Aug 2012, 6:35am
Respirator and goggles. the fan is just to blow the worse of the dust out of the garage and I use my air gun on the compressor to clear the rest off from time to time. I have seen the state that garages can get into if you don't keep the dust under control.
I need to get a proper sander though. The Black and Decker mouse sander works fine but I spend more time clearing or replacing the sandpaper than actually sanding it, plus velcro sanding pads are an expensive way to do it.
Most of the air powered ones I have seen are orbital which leaves me with fears of circular marks all over the body. Tribute had proper long rubber sanding sleds but the y were hand powered which leaves me with fear of hard work. I don't mind hand finishing but there is a lot of sanding and filling to be done first.
26 Aug 2012, 7:09pm
Lots of time wasted today with the family doing picnics by the sea instead of sweating inside the garage. More progress pictures tomorrow including my special long bed hand sanding sled. Works a treat. Idea 'borrowed' from Tribute Automotive.
26 Aug 2012, 7:36pm
I just googled that and got twenty nine million pages of porn... :nono:
26 Aug 2012, 9:22pm
3rd picture, I am the bloke second on the right
27 Aug 2012, 8:04am
Measure twice, cut once, measure twice, cut once, measure twice, cut once, measure twice, cut once, measure twice, cut once, measure twice, cut once, measure twice, cut once, measure twice, cut once, measure twice, cut once, measure twice, cut once, measure twice, cut once, measure twice, cut once, measure twice, cut once, measure twice, cut once, measure twice, cut once, measure twice, cut once, measure twice, cut once, measure twice, cut once, measure twice, cut once
Okay, so the sides of the frame sit on the plastic edges of the door shut, not on top of the actual chassis.
what kind of pillock would cut the plastic away to let them sit flush on the chassis before realising there is a sodding great chassi beam stopping the frame from sitting properly.
Thanks for the explanation Gary and thanks for answering my calls and PMs quickly and clearly.
Top service so far for the whole process so far. Body delivered when promised despite me delaying on the deposit and asking for changed delivery dates. Help people when I turned up to collect the car a couple of hours early. Stupid questions answered promptly and clearly without any giggling at me.
thanks
27 Aug 2012, 12:42pm
Ah, the joys of DIY car building....
Looking forward to next instalment... ;)
(I'm learning a lot from this thread)
27 Aug 2012, 4:40pm
I have made my first sheet of fibre glass.
I think I may have made it a bit harder or stronger than necessary. It was harder to cut than the stuff from Scimitar and the G46 and the Lotus door.
At least I know a bit more about what I am doing. Photos to follow when I get the extra fibre glass off my fingers.
27 Aug 2012, 7:18pm
Ha ha. I had the same problem - the resin's stickier than a sticky thing with a special reason to be sticky. Worth the effort doing it yourself though. :bounce:
27 Aug 2012, 7:36pm
Lost my cable thingy to tie the camera to the computer.
Anyway, frame fitted. Bits of the body sanded but loads more to do.
Grey pipe lagging cut in half makes a great sanding sled.
Ho=nest labour is well overrated. Give me business consultancy and staff instead of hand sanding any day!
Still smiling though
28 Aug 2012, 6:03pm
Brake Servo is mounted on the bit above the front suspension and fouls the bonnet. I haven't connected it to the brake system or clutch yet so I can resite it but i have a question.
It is mounted on a bracket that tilts it back about 30 degrees rather than being horizontal. This looks like it is a design choice rather than an accident.
Does this mean I should mount it at the same angle when I re-site it?
If it has to stay at the same angle that severely restricts where I can put it.
Gary - where is the servo on the cars you have done? From memory, your later 5a's have a different set up anyway so probably not too relevent but any advice welcome.
29 Aug 2012, 8:09am
I've fitted an aftermarket brake servo to my Spyder: it came with instructions that said it MUST be fitted using the angled mounting bracket for it to function properly. It also recommended a non-return valve in the vacuum take off and a hand formed 'U' bend to trap petrol in the vacuum hose.
Hope that helps. :)
29 Aug 2012, 8:25am
Frame on and body offered up.
Looks like the bonnet fits better now I have the rear of the body to align it to properly which is good news.
Just a bit of filler and sanding and it is ready to go!!
31 Aug 2012, 10:56am
All this talk of work progressing on G46 kits is starting to make me feel a bit light headed, i may need to go for a sit down.
Next things you know people will be claiming that they're driving them on the roads. Madness you hear me, sheer madness!
31 Aug 2012, 11:03am
If you look to the right of the last picture you can see what has been slowing my progress. Hic!
