Tuesday
Well, I finally got out to the car and took the drivers door off yet again for sorting out.
When fitted the door, I honestly spent hours and hours, which ran into days, trying to get the door to fit right.
This has nothing to do with Chris's body shell or anything like that.
It has everything to do with me lowering the car way way down, and then getting hit by all the knock-on effects that generated.
The hinges were really out after lowering, I don't mean lowering on the suspension, that came later, but lowering the body shell onto the Spitfire tub.
I knew I could never get the car down where I wanted it by just suspension lowering, so the only other way was to dump the body lower and closer to the Spit tub, ( more than Chris had intended)
So that's what I did, but the knock-on effects which I had not forseen were horrific. and caused me several days of extra work.
Modifying the hinge brackets, the hinges themselves (three times!) the list goes on.
And the list is still bloody going on, hence all the door fitting and extra mods
that I am still doing and will continue to do until I get what I want.
Lots of you out there must have been in the position, where you look at something on your build and think "yeah, I can live with that" but really, deep down inside you have that horrid niggly feeling that you really can't live with it, and you are kidding yourself, and worst still, you know that one day, you will have to bite the bullet, and do it properly!
That sort of day comes to me quite a lot, and it came this morning with regard to the door fit. I knew I just had to sort it out.
Over on the "other side" Paul has just had one of those days and chopped his bonnet in half!! So I know, he knows what I mean.
I've been busy, and its lunchtime already, so here are some explanatory pics
to be getting on with, more after lunch
[IMG]
[/IMG]
[IMG]
[/IMG]
[IMG]
[/IMG]
[IMG]
[/IMG]
[IMG]
[/IMG]
[IMG]
[/IMG]
[IMG]
[/IMG]
[IMG]
[/IMG]
