Couerdelion's 250 SWB Coupe Build
20 Feb 2018, 9:47pm
casamolino wrote:
Good evening , at the moment just at the sides , but may add a couple near the centre to hold down the top edge of the dash , Geoff .
Good, that's same as me - I think it needs bracing in the centre so will look at that in next few weeks.
Thanks
20 Feb 2018, 11:45pm
couerdelion wrote:
I looked at your dash pictures to try and gauge where to cut.
very good !! ...
29 Mar 2018, 9:47pm
Back at it after a month of with the weather.
Another bit of a tidy up and then looked to fit the front end.
Assumed I'd mislaid the nuts that attach the bonnet to the hinges. Spent a while looking till I made the sensible decision to look at the Z3 parked outside and quickly discovered that they are bolts and I need to purchase nuts. Any one an idea of what size?
30 Mar 2018, 7:26am
Hi,
I used nuts needing a 13mm socket so think they are M8. You will need to open up the hinge holes quite a bit to position the front end successfully too (I’ve not Domenic it but seen it on a couple of other peoples builds). So you’ll need some sturdy washers under the bonnet nuts too.
Hope this helps
30 Mar 2018, 10:45am
Thanks Dave. Just been out and bought some M8s. Hopefully they're the ones! ��
30 Mar 2018, 11:40am
Now that you've bought them, I used M8 flange nuts, save mucking about with washers which when your balancing the bonnet, spanner and nuts in one hand make fitting a bit easier. I didn't have to open anything up, it all bolted up perfectly.
Bear in mind that you do have some fore and aft adjustment. Align the bottom rear wheel arch of the bonnet up with the front of the sill.
30 Mar 2018, 11:46am
flange nuts all day long for me unless it absolutely needs a nylock ...makes life a lot easier when you are fighting stuff on your own ...
30 Mar 2018, 4:21pm
damn ... flange nuts of course !
When i did mine up there were three of us so didn't have Jag's balancing act to perform - that must have really sucked. The 250SWB front is heavier than the average politician's conscience
30 Mar 2018, 8:05pm
Nice!
Did you use stronger gas springs on the bonnet?
30 Mar 2018, 8:09pm
molleur wrote:
Nice!
Not yet - I know that I'll need them when I put the centre part of the bonnet in but it holds without it for now.
30 Mar 2018, 8:22pm
Good. Thinking I'll need stronger ones as well. Still waiting for the kits to be completed and shipped.
30 Mar 2018, 9:12pm
You probably know what to order and where from. If not I’ve just ordered some :)
30 Mar 2018, 9:13pm
couerdelion wrote:
Thanks for all the tips folks - was tough fitting it on my own but got the job done.
Did a quick video after I'd finished, for my dad, to show him how I'm getting on...
WhatsApp Video 2018-03-30 at 15.37.53 by couerdelion2013, on Flickr
Good job! Fitting on your own must have been hard
30 Mar 2018, 9:42pm
Did I see something on your thread some time ago regarding the gas struts?
30 Mar 2018, 10:06pm
Not mine. I bought some recently from a uk supplier that fit just right. I’ve bought them for the Kobra but believe the spec is the same
30 Mar 2018, 10:17pm
There are details on the uprated gas struts and order details on my build thread.
Unfortunately, due to me just returning from a beer festival I can't see the post so you will have to hunt for it!
30 Mar 2018, 10:19pm
I struggled on my own as I was worried about spilling my beer..............:pound:
30 Mar 2018, 10:43pm
Oh, I'll find it! Not beer time here just yet..Verry soon though.
31 Mar 2018, 11:41am
Thanks, just read the entire build thread again!
31 Mar 2018, 5:15pm
Not the best of days working on the car...
Decided to tackle the dash.
Made a beautiful template and measured everything up perfectly. Checked, rechecked and checked again.
Then carefully cut 4 holes perfectly into the dash. Holesaw was slightly smaller than needed but decided I could file it out to right size.
Same again for the big dials. This time hole saw was perfect size. Two beautiful holes cut...
Offered up the Speedo to check and it fell through. Vibrations had made hole too big. Shit.
Checked smaller holes and they fit perfect. Decided to trial fit gauges to check. Oil temp, oil pressure, water temp, fuel and bollox, the clock. 5 dials. 4 holes.
31 Mar 2018, 5:31pm
couerdelion wrote:
... hole too big. Shit... 5 dials. 4 holes...
Some days you're the dog, some days you're the lamp-post.
31 Mar 2018, 5:36pm
Lesson learned. Always cut slightly undersized and file or grind to fit.
Bummer my friend. Glass them back and cut them again I'm afraid.
Nearly a whole day wasted to repair. That sucks!
