I think MrTowed's comment about my car are mostly right regarding the windscreen size and shapet bu it's position is more of the problem for authentic looks I think.
The comparison picture below shows the three main problem areas labelled A, B & C. Cutting the screen off would only address the point C, the hieght.
The distance between the back of the front wheel and the front of the door opening (A) compared to the length of the door opening (B) are almost reversed on the BMW and the Maserati.
I guess you could cut the screen off, extend the bonnet backwards, bond the doors shut and cut new smaller ones etc but it does get away from the idea of a quick and simple car modification and you lose the practicality. Remember I am using this car as oine of my daily drivers.
Hmm not convinced by Fii Roadsters, that diffuser/spoiler thing looks like the automotive equivalent of a ghotee beard on the face of a pretty girl. It might be progressive, but I wouldn't want to be seen with it.
if the skirts were to work with the shape of the side profile and the front splitter was turned into a feature that would of bin on cars back then or done in sections below the wing and below the nose. to help work with the period curves. eg small bumper bars that have a slightly sharper profile to catch the wind and pull the front down.
Will the front be lower? Looks high compaired to sill.
The front end isn't positioned correctly in these pictures, and I will be modifying the front valance area to give some more depth and balance with the sill.
Mornin.. Still watching this with interest....still a little concerned about the 'bulbous' look of the front wings / arches....so here's another daft idea..
I know the bonnet line and centre front cant go any lower because of the engine / front panel, but how about..(wait for this..) doing a pie cut the whole length of the wing, where the inside curve meets the 'bonnet', under the headlight, and back up the outside of the wing, between the arch and the top of the wing...starting with nothing at the back, upto a couple of inches at the front.. (like the whole top of the wing is a lid, put back on a bit lower...!)
Then the lines would flow and all will be well with the world...
The idea works in my head anyway...!!
All the best
I think this looks fantastic, will be nice to see how low Chris can get it but I'm sure he'll be putting those photoshop skills to good use before we know it.
