1iTim's triumph miglia special
19 Sep 2014, 8:14am
How long does the shipping take, 2months?
19 Sep 2014, 9:57am
Hi gary, transit 38 days. Customs clearance....
I'll tell you when i get it!!
19 Sep 2014, 12:57pm
Hopefully not a Christmas present...
21 Sep 2014, 8:13am
Not a lot of visible progress. inlet is cleaned and in place. However the set screws dont line up with the mount points on the headers. why are they there anyway? They seem only on the mk2.
21 Sep 2014, 7:52pm
Its good to see you have as many bins as i do... the car is looking good, too.
4 Oct 2014, 5:32am
Been thinking of an engine upgrade, maybe a honda 1.6
<a href="http://s1332.photobucket.com/user/1iTim/media/Honda%20f1%202015_zpsk65any7n.jpg.html" target="_blank"><img src="http://i1332.photobucket.com/albums/w612/1iTim/Honda%20f1%202015_zpsk65any7n.jpg" border="0" alt=" photo Honda f1 2015_zpsk65any7n.jpg"/></a>
4 Oct 2014, 5:36am
Been thinking of an engine upgrade, maybe a honda 1.6. Should have enough power
4 Oct 2014, 5:45am
Maybe not as the hours i just spent on these hs2s with 600 wetand dry would go to waste.
One jet broke in transit but vendor sent me another 2. However they are visibly different jet hole size. Lucky one is a match (86 thou) to the ones i already have, so it will b one red one black but same on the inside.
8 Oct 2014, 10:31am
my first bit of original manufacture, fairly simple to start, a heat sheild:
8 Oct 2014, 10:34am
Very nice. Fabrication is good for the soul.
8 Oct 2014, 12:32pm
Good stuff!
You'll soon be making all sorts of complicated rubbish just like me!
8 Oct 2014, 7:57pm
Thanks. Im working on deeper grease caps made from a peice of al pipe conector. I hope to build most little ducts and fairings from hammered aluminium rather than grp. But we'll see how that goes!
8 Oct 2014, 9:49pm
Keep up the good work 1iTim the heat shield look's just the job, are you going to round the corners off.
It's a big learning curve is metal bashing and practice makes perfect as they say, there's also plenty of vids on you tube.
Looking forward to see what else you make.
11 Oct 2014, 12:40pm
Swifty my wife said " is it finished?" When i proudly showed her. i have since cut out a bit to enable the dipstick (and folded edges over neatly) all other corners will wait for the body and bonet before trimming and edge finishing. It will be polished too. I'll post about the gease caps when they r done and work!
Tim
3 Dec 2014, 8:03pm
Any movement forward recently T?
4 Dec 2014, 8:24pm
Hi pj nice to hear from u, no progress, waiting on the kit from mike
Best, tim
12 Dec 2014, 6:29pm
Hope there hasn't been a problem at customs Buddy . Should you consider looking into it's whereabouts ?
16 Dec 2014, 3:55am
no problem at customs, i'll keep you all posted as i can.
merry christmas all!
1iTim
24 Dec 2014, 10:54am
Merry christmas my internet friends, and may the new year see many happy registrations!
Tim
26 Dec 2014, 10:00am
Nice to be in the Build Cue.
Nice to read your build diary 1iTim.
I'm just behind you with my build. All my suspension parts have been cleaned and painted, the chassis been cleaned and painted. One coat to the top and three coats to the underside. I've had assistance to turn the chassis right side up now, but its been so cold and I really want to give the top side another paint layer before I start my build.
I have also been distracted with renovating a set of 15" wire wheel I purchased early December, which I want to try and renovate myself. If I fail then I can get them done professionally as there is a company a couple a miles away.
27 Dec 2014, 1:05am
Thanks carib. I got the chassis blasted and powdercoated, worked out not much more than the self paint option, and then it looked so good it has lifted my quality ever since.
Just waiting on the body now. If you are talking to mike say hi from me.
Tim
30 Dec 2014, 3:02am
My custom grease caps polished and in place. Made from a 42mm dia al pipe
30 Dec 2014, 3:07am
And the carby piston dome things:
(before and after...)
30 Dec 2014, 10:01am
Cool solution for the grease caps and you can't beet a bit of serious polishing, the carb dash pots will look great, are you going to polish the carb bodies?
30 Dec 2014, 12:08pm
No, just the tops. The bodies and floatchambers would need a lot of work to prepare for polishing, lots of cast flashings and stuff to file off. So no. Would look awesome, anyone done it?
Was going to put the carbs on today but first need to plumb some kind of crank ventilation to replace the open vent. Then i can get them on and linked.
t
