#47 Spyder
3 Mar 2014, 8:52pm
Michiel ..... that is FANTASTIC ! a great idea to copy:thumb:
Seating looks soooooo retro.
Keep it up
Slarti
6 Mar 2014, 6:54am
Hi you all,
Since I reached the stage of placing the bonnet, I had a problem with pieces of engine sticking out of it and a radiator beeing pushed down to street level.
Off course, this means scoops. The shape of the thermostat housing and the hose coming out of it, directs a pretty wide scoop. As seen before with manny Spyders. I wanted a more narrow scoop and this ment that I had to change the thermostat housing.
As fot the radiator, I decided to have one made according to my own specs. I want a system with an expansion tank, a filler screw, connecting pipes at the right place, correct mounting, hight, with, sensor for the electric fan, sufficient colling capacity, correct mountng for the electric fan I have. Well, there was no way a stock radiator would meet all these needs.
Also I had the expansion tank changed. One pipe outlet was plugged and one pipe at the under side was changed in shape and diameter.
As you can see here, I used the bracket for the expansion tank to mount the remote reservoir for the master brake cilinder as well.
Michiel
6 Mar 2014, 3:45pm
Nice work, I'm hoping to start catching you up soon!
7 Mar 2014, 7:02am
Hello Viatron, for catching up, you have to hurry I guess. Because this is my last report for a short while. I still can tell you how I made the bonnet scoop. But after this job, my car was sent to meet his maker...
Let me explain that. I gave it a good thought. I was thinking that with the effort I made so far, I want the best prep and paint job I can get. It would need experience/skill to straighten the body (the new rear I made wasn't that perfect as it turned out), rework the gaps, finalise the grill (the hoop wasn't centrered seen from the outside), check the roundness of the wheel arches etc.
There could only be one who could achive the workmanship and quality I want and still would be affordable, and that would be it's maker that laminated this particular body (number 47) three years ago.
After arrangements I put a lot of post stamps on it and had it shipped to Poole where Mike (mikmiglia/Miglia sports cars) will perform his work and give this car the finish it deserves.
Work has all ready started, so fingers crossed now.
Michiel
7 Mar 2014, 8:22am
Shame you weren't able to finish it yourself Michiel, but well done for handing it over to someone who can rather than abandoning the project. Look forward to seeing the finished article. :)
7 Mar 2014, 9:34am
Michiel , I am looking forward to seeing this one getting finished , it is a really nice example of the range.
As a point of history for you , Mike was heavily involved in turn key builds and kit preperation by the time your car was made , number 47 would have been made by one of the part time laminators that were being used by then.
Mikes forte is bodywork , he has grown up around bodyshops his whole life , working for his fathers busy shop from a very young age after school , weekends etc. His finish work and prep will be first class if he is on board.
7 Mar 2014, 6:52pm
Michiel - I bet you were nervous when your car was lifted up on the forklift!
Although, that doesn't look as bad as the crane lifting a Sammio over the top of a house. :scared:
I think Mike will do a great job preparing your car and it will look great when done. :cool:
9 Mar 2014, 10:17am
I have received a message out of Poole. The car was delivered without any complications I came to hear about. So that is a releif.
@Paul, I made a wooden frame. That way a fork lift won't damage the underside of the car. This worked well. Still, nothing beats solid ground :eyebrows:
@Towed. Abbandon the project, like in abbandoning the ship? I think I don't understand. I'm not abbandoning the project, au contraire, I'm having the car sprayed so that I can finished it and drive it :eusa_dance:
@el primer, you must be right about the laminators. It's just that I talked to Mike on collection three years ago, and this lead to my assumption that he made the body
Anyway, I still have some pictures left that concerns my scoop, which I will post now.
Now that my thermostat housing is changed, I could look out for a narrow scoop. After searching for shapes that I could use for the building of the scoop (or bulge). I found a vase that I thought, had a nice shape.
After waxing, I gave it a gelcoat.
After this I laminated it, to make a mould. With this mould I made the final scoop.
For the little scoop/bulge that was needed to cover the above of the first carburettor, I used a plastic gardening shuffle.
It all lead to this:
I also made a mould that has the shape of a sfere. With the scoop and the sfere, I can make a bulge. After some consideration, I choose for the scoop and not for a bulge. A bulge would change the shape of the bonnet beeing more of an integral part. A scoop is more laying on top of the bonnet leaving the bonnet shape as is.
Michiel
9 Mar 2014, 11:08am
Like the scoops, bet you can't wait to get it back and enjoy driving it :thumb:
9 Mar 2014, 12:16pm
Can I ask what triumph the gearbox cover is from? I had to cut mine about a bit to get the gear leaver to fit through and think yours may be more suitable
Mac
9 Mar 2014, 9:37pm
Hi Mac,
Maybe we have the same cover, mine had a horrible fit! My cover should be a Triumph Vitesse cover. At least, that's what I ordered.
Nevertheless, I got it sorted out in the end. But it took a lot of fiddling and there is some tension on the screws.
@mas, yes I want to drive it! It took a ride of approx 4 m's to get the car to the load area. It was a hell of a ride. I want plenty more of that.
Michiel
19 Mar 2014, 8:00pm
Scoop
Hey Michiel,
You're going strong with the built - very impressive the quality standard you achieved. I was surprised that you shipped it to Poole for the exterior finish, but you're right, they know best how to handle this body.
I have made a cut out in my hood as well to let the air filter through but also have been looking for a good shape to laminate a scoop. Sofar not found... Is it anywhere possible to borrow your "Vase"? - the size seems perfect...Please let me know...
I'll post an update on the 2cv next week, we have had to do a lot of reshaping of the body with filler.. The body is really full of gaps and not straight at all.
But we are now getting somewhere, it's a lot of work though and had to call in a friend that is good with filler..
Cheers,
Marcel
19 Mar 2014, 8:29pm
Hello Marcel,
Bringing the car to Poole was my best idea. This is no job for an ordinary paint shop. I want best.
You can use my mould, no problem.
Regards,
Michiel
3 Apr 2014, 7:28pm
Hi you all,
Finally I have some progress to report. And what progress it is! I received pictures out of Poole, where Mike and his co-workers (from Miglia sportscars) have prepped and sprayed my car. I live in Holland, but I wanted a quality GRP paint job and figured that I should take the car to the other side again for that. It was more then a regular sprying job. Mike did loads of work, correcting all my work where necessary to get it top notch. And for a fair price I would say. Thank you Mike.
I changed my mind on the colour many times, before we came to: Jaguar Bronze metallic. A beautiful 50's colour. Totally different from all the colours I have seen on our kits before. Now it looks distighuished, but wait how it looks with the leather and the panamericana stickering I have planned.
What do you say?
Michiel
3 Apr 2014, 7:56pm
Yes ...now that works!!!!,
Great choice
3 Apr 2014, 9:13pm
Prachtig!
3 Apr 2014, 9:13pm
great colour and car looks pretty straight .looking forward to seeing this one fitted up and the Carrera Panamericana scheme sounds pretty cool.
4 Apr 2014, 8:03am
Mike Miglia - Another great finish, well done sir.
Michiel - You must be pleased, as your car looks fantastic. :cool:
I can't wait to see it all put back together and ready for the road.
Good luck with the final part of your build, Paul. :)
4 Apr 2014, 8:14am
Very nice colour choice expertly applied - it looks just stunning!
Now, get it back home and complete the fit and finish pronto.
You're going to love driving it and the people of the Netherlands are going to be blown out of their clogs when they see it blast past (no racial stereotyping intended with the clog thing).
And it goes without saying that we like to see loads of pictures!
4 Apr 2014, 8:49am
Mister Towed wrote:
You're going to love driving it and the people of the Netherlands are going to be blown out of their clogs when they see it blast past!
Seeit!!!
Did you see the megaphone exhaust!!!!!! They will be hearing it first..ha ha
4 Apr 2014, 8:57am
redratbike wrote:
Seeit!!!
Which megaphone exhaust are you talking about? Nothing really leaps out of the pictures, let's just have another quick look...
Oh, hang on a minute. Ahh yes, spotted it now. :nerd:
4 Apr 2014, 9:21pm
Great colour and inspirational finish.
5 Apr 2014, 7:50am
Thank you all for your kind remarks. Next week I'm going to collect the car and I can see it in real life. I'm exited I tell you.
I like the megaphone exhaut (mounted properly offcourse). But I'm affraid it has to go. I can't controll the sound :horn:
Even with a DB-killer inside the silencer, it sounds like there is no silencer at all. Lovely sound, but a bit loud for road use.
michiel
5 Apr 2014, 8:24am
michiel
Can't you fit an intermediate silencer to tone the sound....there are some that have variable baffles to Taylor the sound these days
5 Apr 2014, 4:31pm
very cool car and colour ....yes i have to say the best so far great work well done ..like towed said take it home and have fun ..the open road is waiting..............
