We'll get it sorted. Looking very full now with 3 Heralds in Turnkey strip, Mac's Spitfire, Development Spitfire/Navigator (The Green one), Colani, Demo Pilot (Vanessa) and Demo Navigator about to rejoin after spray. Just as well we went for the big workshop
Photos will follow (Once I get Andyp85 to sweep up a bit!)
First update today from andy, work on the frame redesign is underway
On another note does anyone have a spitfire 1300 or 1500 front pully to hand? i need the diameter of it just behind the v so i can order a trigger wheel to weld onto the back of it as i will be running a Nodiz electronic ignition system.
Oh and if anyone wants to go nodiz I'm on a forum that is currently getting 20% off, makes it much easier to get the best from your engine and very easy to install.
[url]Www.nodiz.co.uk[/url]
So I'm sitting outside my hotel in the sunshine waiting for dinner, so what to do? Go gauge shopping that's what!
Now I know that the "Ribble Navigator" on the quad gauge is out but the speed hut website isn't clever enough to deal with an apple device just yet but I know on the full browser version you can move the text so that's easily solved. The speedo is GPS driven which I'm fairly sure isn't "strictly" legal but apparently it's pretty accurate so I'm willing to take a punt, what do we think?
Ps should have mentioned that these are 4" gauges and the speedo also has signal left and right and a high beam light. All the gauges on the quad gauge are programmable. The pair customised and shipped will cost me $660 US plus whatever the customs man decides he is due so I'm reckoning about £520 at my door including all the sensors apart from the fuel level sensor.......
I think they look nice and period, shame about the LCD on the speedo but you can't have everything, and for the money I haven't found anything close in the EU as good
Thanks Gaz, don't know if you've spoken to Andy today but caught him earlier I between super cars and I'm coming up next Tuesday to have a look at progress and discuss time lines etc.
That's the other thing I like about them Paul, as well as looking vintage to some degree they will make the layout a simple job. The other thing I like is that they would appear to be very easy to wire up so less work on the electrics, I'm now officially bored with complex electrics, the other project has a stand alone ecu, data logger, electronic dash and a 4 camera video system, the loom in places looks like an anaconda !
No mention of it needing to be mechanical or electronic, it just has to work, and must indicate both mph and kph if the donor was registered after 1st April 1984.
It mustn't indicate more than 10% (+4kph) more than the actual speed of the vehicle and must never indicate less than the actual speed.
None of the above is checked on the MOT either, the speedo just has to be present and intact.
I've regularly conducted speed calibration checks on job cars over the last few years - If I've followed and prosecuted someone for speeding, if it's practicable, as soon as possible afterwards I do multiple passes down a quiet stretch of dual carriageway holding the speed at 10mph increments above and below the speed I believe they were doing, while a colleague checks my true speed with a calibrated gun.
So, if it is my opinion that they were going 70 in a 50 limit, I drive at an indicated 50, 60, 70, 80 and 90mph, while a colleague checks my actual speed. We then write statements that show the margin of error between the indicated and actual speeds which gives me an evidential argument as to how fast the motorist was really going (we have other methods too, btw).
The cars have a traditional speedo and a speed reading on the (Garmin) sat nav, and the sat nav has been spot on every time, while the built in speedo is often reading 10mph high at 100mph, showing 110mph on the clock and 100 on the gun. Don't take it as gospel, but I'd trust a gps speedo over a mechanical one any day.
The only drawback I can see with a GPS speedo is that it won't work when you go through tunnels. I'd suggest you get to know what speed you're doing at what revs and monitor your speed that way when it's not working.
Oh, and in eight years as a plod I've had a lot of people contest their speeding tickets but I've never lost a case.
Nice dials by the way, a tad expensive but very nice.
If its not legal for the speedo then I suppose my two 38mm machine guns rocket launcher and revolving number plates will have to come off!!
Ha Ha. Can't find anything in the construction and use reg's prohibiting the machine guns and rocket launcher, but the revolving plates would constitute 'going equipped' and get you nicked.
RHQ had a very welcome visit from Mac yesterday which resulted in a lot of progress being made with the redesigned Navigator frame. We've just about sorted the rear end and floor supports:
Glad to say that all joints are at right angles where they need to be and holes line up with the chassis We'll be finishing off the rear today and moving on to the front end which has three main functions. Obviously supporting the body shell at the right height, providing a support for the master cylinders / pedals and also giving the steering column some good support.
More photos will follow soon. (And many thanks Mac)
More frame photos. The rear is starting to near completion. Just a couple more braces for the fuel tank support and a cross brace on the rear cockpit former and I'll be looking at the front next.
