Food for thought!
Do I talk nicely to Gary and try and coincide an inspection with the proposed meet-up....or do I attempt to be the first to go through the inspection at Maidstone....dilema?.....the other problem is I washed the purchase receipt...do you need it for the inspection? (I know..you are meant to launder the money not the recepits)
Food for thought!
Nick, it might be worth having a call to the local Maidstone office first. If they sound receptive to the idea and don't want to make a mountain out of it, it may be more convenient.
That said, a day out to Poole is a small price to pay for a simple, hassle-free inspection, attended by Gary himself to ensure there are no problems.
I would suggest doing the inspection as soon as you can, to get it out of the way and so you can then relax and continue the build! It is not difficult, but a great feeling when it is done!
Having the ends of the rear outriggers corrode through and drop off the very afternoon after the inspection is an amazing coincidence, it's just lucky it didn't happen a few hours earlier or you'd have had to weld new ones on...
Oh, btw, did you actually need to show them the receipt for your Sammio body? Only mine got turned into a mouse nest when I left it in a box of bits in the garage.
No reciept was required. In fact, they have just called me and asked me for the mileage as they forgot to take it They didn't ask for any paperwork, apart from the logbook and the completed form from gary's website, which were given to them when we booked the inspection.
Wow, great progress and it looks like your bonnet actually fits!
Well, to a degree. Still needs some fettling. It hit on the thermostat housing exit pipe and I don't really want a scoop, so I cut it shorter which seems to make a difference. Everything else, including my header tank clears the bonnet okay.
I have also got to do some minor adjustments to the hinge points so it will sit a bit better over the wheels, which in turn I think will muff up the shut line again.
The secret to this stage is to make small adjustments and take a step back, have a coffee and do a bit more. It pays to take your time on the bonnet I reckon as learned from Davecymru, who found moving the bonnet forwards with the 6 cylinder engine helped the look. Once I have it all so I am happy with it I am going to take the 80mm lowering block out of the back spring and reduce it to 60mm so it lifts the back end up a tad. I reckon that will help with the 15" wheels and make it sit better.
I will have a play at the weekend now, as I am busy the next couple of days with work... hwell:
I have decided on Pepper White which is the creamy white that is on the new mini's. Black wire wheels and interior. Subtle and a little bit classy (or Gay as Gary called it! )
looking good...and spurring me on a lot....I might just be upto inspection stage after the May B.Hol.
Have to agree with you on the cup of tea and ponder route.....just realized how stupid I may have been bolting on the fuel tank prior to fitting the frame!!!!looking at the tweaks I will need to do the holes won`t line up on the tank after will they .....The good thing about all this as a build virgin,ray2: is that I will know for the next one
