Whilst my progress has slowed down lately, at least the bulk of the boot lid work is done.
I'd be happy if I have got the lid sorted and made a start on the bonnet before Christmas.
Then I've have the Christmas break to recharge my batteries and carry on.
Drain Holes:
I turned the body shell over, and then realised I should have done the next job first.
Rather than turn it back over, I simply did the work while lying on my back instead.
I opened out the inside of the rain channel hole so that it "joined up" with the fibreglass funnel I'd built around the bottom corners.
Note:
I was happy with the rough finish, as I will be using filler around the pipe. + Obviously the photo was taken upside down too.
Then I tidied up the other side of the holes.
I also tidied up all the other edges of the rain channel while I was at it.
A blob of plastercine was enough to temporarily hold the plastic pipe in place.
Then some fibreglass filler was used to set the position a bit more permanently .
I also used the same filler to tidy up more of the rain channel edges.
Note:
Although I have covered the bolt holes with filler, the holes are "intact" on the other side, so easy to re-drill.
As it was so cold outside, I had to leave it a bit longer than normal before giving it a rough sanding down.
I will now leave this to set fully overnight before giving it a skim of normal body filler.
With rain due later, I've tucked the body shell away and will now be returning to my Christmas duties.
Not a great photo, but I hope you can see that the wide end of the tube is below the level of the rain channel.
Once I remove the plasticine, I will be able to add some fibreglass filler around the tube to hold it in place.
I will also use the filler to form an internal funnel from the outside edges of the drain hole to the tube.
Did I mention it was cold outside?
As despite typing this post up indoors, my nose is running and my fingers and toes are still cold!
