Slowly Edging Forwards:
Spent most of the weekend down in Sussex for my mate's birthday bash.
As we drove home through the pouring rain yesterday, I did contemplate the wisdom of building a car with no roof.
Still, at least it wasn't raining this morning, so I finally managed to get some car work done.
When I peeled off the covers, it was clear I have put the rain channel drain holes in the right place, as that is where the water gathers.
I also put the boot lid back into position to check the gaps I needed to fill & thankfully it is just the centre section.
Note:
The lid is sitting a bit higher at the moment due to the fact I haven't trimmed back the re-worked bottom corners yet.
So one small fibre glassing session later and this is what the rain channel looked like.
Given how cold it was, I decided not to attempt any upside down fibre glassing, as it was bound to end in tears.
So I waited until the first round was initially set before turning the body shell over.
I wanted to build up the "pipe" section of my drain holes...
And add a bit more "cross bracing" to the top edge bolt mounting plates.
One part of this plan went well.
But the other turned into a complete mess.
Somewhere along the line, water/moisture got into the resin/matting for the drain holes.
When I saw the matting going "milky" I knew it was time to stop, abandon ship and remove everything.
As it turns out, this may be a blessing in disguise, as getting the matting around the cable was a real struggle.
So I may have a look for small section of plastic pipe and 'glass that to the bottom of the "funnel" instead.
It was only when I moved the shell out of my wife's parking space did it dawn on me what went wrong.
I removed the foam formers from the rain channel.
There is still a bit of work to do here, but at least the basic shape is in place.
As I wasn't going to be using the cable in the drain hole, I removed it and most of the plastercine.
Trapped water kept leaking out while I was doing this, so that was the source of my earlier problem.
My next job will be to tidy up the inside edge of the rain channel so the rubber seal will fit.
I will also be adding some filler to provide a smooth surface on the bottom of the rain channel.
So until next time, take care, Paul.
I can't really complain too much about the conditions on the front drive.
As my mate in Buffalo sent me this photo of the front of his house!
