There will be a slight delay before presenting my Spyder for its re-MOT while I take steps to avert a potential disaster.
Yesterday I replaced the leaky o/s brake cylinder with a shiny new one, delivered less than 48hrs after placing the order with Rimmer Bros (other Triumph parts suppliers are available). That took about three hours and I had to go to work mid afternoon so I decided to pack up and replace the other side today.
So, I needed to quickly bleed the brakes, put the adaptor and wheel back on and drive the car back into the garage. So far so good. I have an easy-bleed tube so it only took a couple of minutes to get the air out of the line and lock down the bleed nipple.
I then checked for air in the system by standing on the middle pedal. First press, nice firm pedal. Second press, pedal straight to the floor and a jet of brake fluid shoots across the drive at a 45 degree angle to the car.
Now, when I bought my donor, one of the selling points was that it had recently been fitted with a nice, shiny set of new copper brake pipes. You kind of assume that they'll have been fitted properly, don't you? So, when I took a look under the rear wheel arch and found this -
I wasn't too impressed. The brake pipe had completely come out of the union because
there's virtually no flare at the end of it.
If it had let go when I was driving back into my garage I'd have wrecked the front of my car. If it had let go as I slowed for the roundabout near my house on my way to the MOT last Monday, as a 35 tonne artic thundered across my path, that would have been the end of me.
So, I've now bought myself a flaring tool and will be disconnecting every union and checking for a decent flare at the end of every pipe before my Spyder turns another wheel under its own power.
I'm off to the gym now to burn off some anxiety induced stress and will aim to have all the remedial work done for a retest on Tuesday.
I'd strongly recommend that anyone buying a donor with a single circuit brake system checks and double checks all of their pipe unions before going out on the road. I really wish I had.
